piston weight
Old Nov 21, 2014 | 01:02 PM
johnnyjaws's Avatar
piston weight
hi all I just bought a bbo that needs a rebuild . it has low compression pistons in it can I put a set of stock high compression pistons in it with out having to rebalance anything?. im trying to find out what my stock low compression piston weighs .I was told I can go 3% heaver or 7% lower on piston weight without any changes any input would be appreciated.
Old Nov 21, 2014 | 01:48 PM
steverw's Avatar
I dont know the answer to your question, however if you have the pistons out then you are very close to having the crank out too. Balancing is one of the cheapest and BEST things you can do for an engine. Especially if your building a "high compression" performance engine. Others will know the answer to the question you asked.
Good luck
Steve
Old Nov 21, 2014 | 05:41 PM
cutlassefi's Avatar
Who told you that?
Old Nov 21, 2014 | 07:00 PM
johnnyjaws's Avatar
a mechinist sosenson performance can u give me more input.
Old Nov 22, 2014 | 05:02 AM
cutlassefi's Avatar
I was told I can go 3% heaver or 7% lower on piston weight without any changes.
Before what happens? 3% of a 750gram piston is 22.5grams. You'll most likely feel that. And although an imbalance on the heavy side is less of an issue, I guarantee you feel the 7% of 750grams. That's 52.5grams. You'll feel that no doubt. And it'll negatively effect bearing life at that level as well, guaranteed.
He pulled those figures out if his butt. Get it balanced, but not by him.
Old Dec 23, 2014 | 02:23 PM
johnnyjaws's Avatar
I have to have the cyclinders bored out .030 could some one recommend a good set of pistons to put in my 455 they had low compression in them id likem to go to a higher compression piston and still use pump gas ill be putting c heads on the motor and using a comp cam h274 cam
Old Dec 23, 2014 | 06:39 PM
cutlassefi's Avatar
Either Icon IC886 or equivelant Wiseco. And with stock C heads I'd do a different cam.
I'd still find another machinist based on your earlier comments as well.
Al2011
Mar 15, 2017 11:29 AM
ztim
Apr 28, 2007 01:25 PM
rustycarr
Feb 27, 2007 06:52 PM
jbroom
Dec 9, 2006 03:57 PM
<Franco>
Feb 17, 2005 03:05 AM
