Piston/compression ID help
Old Jun 22, 2013 | 11:40 AM
1970supremevert's Avatar
Hello all
I have a 455 & would like to know if anyone can " best guess " what the compression ratio would be with these pistons, all stock motor, Ka heads
block casting looks to be after 72 , starts with L 3 E. any help would be appreciated
thanks in advance
Old Jun 22, 2013 | 12:14 PM
oldstata's Avatar
Justin
You proble know ka are big valve heads and those look like low compression pistons to me I been told my 72 block with the same set up is Luke 8.5:1
Maybe some one with more better info can clarify for the both of us
Old Jun 22, 2013 | 01:08 PM
Ah, the optional "soup bowl" pistons.
CR will be, well, low. Add the FelPro blue head gaskets and you'll be lucky to be close to 8.5. Good candidate for a supercharger.
Old Jun 22, 2013 | 03:09 PM
thanks I will order won ton, well at least I can run pump gas huh
thx
Old Jun 22, 2013 | 04:41 PM
cutlassefi's Avatar
Those don't look like big valve heads to me, they look like 2.00 intakes.
Old Jun 22, 2013 | 04:53 PM
oldstata's Avatar
Justin
Did they make ka heads with the small valves ? I thought they were w30 replacement and industrial use the big valve ?
Old Jun 22, 2013 | 06:27 PM
I will meaure them on Sunday
Old Jun 23, 2013 | 08:54 AM
X2. The big valves nearly touch. That's a 2.000 intake.
Old Jun 23, 2013 | 12:24 PM
oldstata's Avatar
Justin
Here is a pic of my Ka head valves think you guys are right never new that they made a small valve Ka head
Old Jun 23, 2013 | 01:10 PM
KA heads were used on marine and industrial motors in the 1970s. Just because the factory lists them as performance head replacements doesn't mean they all came with big valves. Not a lot of "performance" going on in the mid-1970s, unfortunately.
Old Jun 23, 2013 | 04:01 PM
measurements
2.06
1.62
Old Jun 24, 2013 | 09:33 AM
oldstata's Avatar
Justin
Originally Posted by 1970supremevert
2.06
1.62
So would this be big valve ?
2.0 small
2.072 big ?
1970supremevert
Jan 25, 2014 05:24 AM
boondocker
Apr 22, 2011 12:47 PM
dkraus71cutlass
Apr 1, 2011 09:34 PM
69Rman
Mar 27, 2010 10:22 AM
