Pennzoil 10W40
Pennzoil 10W40
I would like to get peoples opinion on the quality of Pennzoil 10w40 conventional oil for use in my 69 442 with just under 60,000 miles. I addition to the oil change I intend to add ZDDP and a WIX 51049 filter at the oil change.
How much ZDDP should I add?
I am trying to get away from using synthetic oil due to oil leaks discovered after using synthetic
Jerry
Jerry
Jerry
Jerry
Thanks Joe and farmer.
I appreciate both your input.
I have seen numerous post here and on the other site that I visit that have advised to use zddp when using a flat tappet cam. May I please ask why you guys don't see a need to use it.
I'm planning a 4000 mile trip this coming spring and want to give my 442 the best chance of making it with no problems.
Thanks again
Jerry
Thanks again
Jerry
Thanks again
Jerry
Thanks again
Jerry
Ken
As I mentioned in another post, in order to obtain the API approval (donut), the oil must pass a series of engine tests. The tests are more severe than any street engine will experience. These tests are developed to qualify the oil for not only today's engines but also older engines. In other words to assure "backwards" compatibility. There are many different opinions on the use of ZDDP. New lubricants are light years better than oils from the 60s and 70s. I worked in the lubricant industry for over 20 years (not blowing my horn) but I never saw any issues with today's lubricants in older engines. Be your own judge but my recommendation stands - use a major branded oil with the API donut and correct viscosity grade. As for synthetic, I don't see a need unless you have high operating temperatures or cold ambient temperatures. There is potentially a fuel economy benefit by using synthetic but may not be worth the extra cost of the oil. I am talking about "street" engines and not race engines.
Ken
Ken
I used to think that way until I wiped out a cam. Now I'm very cognizant of the oils I use. I recommend getting educated on oil differences. Not trying to bash farmer52, he probably has a lot of experience in the industry and as Joe said for a stockish engine it may work just fine.
You can get all sorts of opinions on this subject. I usually add a bit of the Zn compound. Finding out what's already in the oil is the hard part. My "guess" is to try to keep it around 1200-1400 ppm. If I were not adding any of the Zn and had to choose between the readily available oils, I'd probably go with either the Rotella or the Valvoline VR1. The dedicated oils are probably better if you don't want to add the Zn, but they are a bit harder to find and usually more costly. In your summer you could probably use the 20W-50 especially at higher speeds. The long Wix filter seems like a good choice for all around general use. They put a nominal micron rating of 21 on it.
Using a Diesel engine oil is a good option. But the ZDDP level is dropping in DEO because of "poisoning" exhaust emissions aftertreatment devices.
If you want to know what is in the oil, send a new oil sample to an oil testing lab. For a few dollars, they can give you the oil "finger print".
I do believe that my command level decision in this major oil change discussion will be to add about 2 oz. of ZDDP to Pennzoil 10w40 and I shall sleep well and my wallet will be ok for another day.
Thanks to all for your input
Jerry
Jerry
