Is it okay to T vacuum components?
Old Mar 10, 2021 | 08:42 PM
4speed455's Avatar
I have two manifold vacuum sources on my 455 and I need to connect three things. I removed the TCS/TVS stuff and I have the PCV going straight to the carb but I still have the transmission modulator, distributor advance and a/c reservoir that all need manifold vacuum. Would I be okay T’ing them all together or should they have their own vacuum source? If I could T them all together that would be preferred to clear up any clutter but I do I have two ports on my manifold if one of them needs a dedicated source. TIA
Old Mar 10, 2021 | 09:17 PM
I've T'd the modulator and the vac advance together. Leave the PCV on its own as well as the vacuum to the a/c.
Old Mar 10, 2021 | 09:24 PM
That should be ok.
Old Mar 12, 2021 | 06:29 AM
oddball's Avatar
+1. The PCV moves quite a bit of air, so leave that on its own. The rest can be t'd together. Vacuum brake booster is also usually on its own.
Old Mar 12, 2021 | 09:08 AM
jaunty75's Avatar
Certainly!
Old Mar 12, 2021 | 10:27 AM
4speed455's Avatar
Thanks for all the replies. I knew certain things could be connected I just wasn’t sure if anything needed a dedicated vacuum source. I have the PCV dedicated going to the base of the carb and the brake booster is also dedicated going to its own fitting on the intake. Looks like I should be okay connecting the distributor advance, transmission module and a/c reservoir together and plugging the other port. That will keep all the vacuum hoses behind the carb so it will look pretty clean.
Old Mar 12, 2021 | 07:02 PM
On the other hand, if you've GOT ports, use them.
Old May 4, 2021 | 06:37 PM
cfair's Avatar
Vacuum lines are also a great way to learn how to flare and bend tubing with out risking safety. Cleanly bent hardliners to the brakes, and PCV look sharp and work well, but aren’t factory.
On my 455’s the PCV is direct to the qjet’s big front port (3/8’s, I think), brake vacuum is on its own too. Distributor is on its own port.
Vacuum accessories like A/C, power trunk, power door locks are on a common line (“T’d”) with a major league Caddy vacuum reservoir stashed under the passenger side fender. What’s weird is the setup is the same for both cars, but the Starfire holds vacuum over night and my 98 doesn’t. Miles of 55 year old rubber lines is likely the cause.
Sorry for late reply, been away a while
cf
biggus
Jul 3, 2015 03:28 PM
Crockett 999
Feb 1, 2015 01:18 PM
rcdynamic88
Oct 19, 2010 06:05 AM
ctrain22
Sep 8, 2009 04:05 PM
DAN76
Mar 31, 2009 10:30 AM
