Oil pump pick up to oil pan clearance on 455 street build
Measured the pick-up screen to oil pan clearance using clay , looks to be about 1/2 " is that too much ? Running a Thorton 5 qt pan / melling high volume pump.
THX in advance
THX in advance
I always set my pickup screen to 1/4" at lowest point; that's measured without gasket in place. If using a "press in" pickup, recommend tack weld to hold it in place.
