Oil - Intake Problem?
Big Block 455, 60 Over. Have Had A Problem With Oil Collecting In The Edelbrock Performer Intake Runners Which Causes Engine To Smoke. Tried Different Gaskets,( I Should Buy Stock In Fel Pro) Adhesives Etc. Also Tried A Cast Iron Manifold.
Started Out With C Heads That Were Ported, Changed To A Set Of G Heads Not Ported, Same Problem. I HAVE RULED OUT THE PCV.
Need Help ! Anybody Out There Ever Have A Similar Problem Or Have Any Ideas.
I Used Mr. Gasket # 404 (recomended By Edelbrock) Numerous Times With Different Adhesives. Also Found On The Mr. Gasket Web Site Under Installation Tips To Use The Valley Pan Gasket Together With The # 404 Gaskets. Problem Still Persists
I would look at intake for possible crack and if there are any threaded holes in the manifold for plugs make sure they are there on floor under carb and underside. Thick paper gasket from MR Gasket should seal......
svnt442
Jul 17, 2011 04:43 PM
