I found this intake manifold for sale. I don’t know anything about it. Is this a good performance piece or should I stick with the Edelbrock performer? He also said it’s for a big block can anyone confirm? Thank you.
Run, don't walk, away from that intake. It's a complete gimmick. There's a reason why no other manufacturer has copied that design in the last half a century.
I think the dual port is the only manifold that we won’t test. I was hoping to find one super cheap at Homecoming just to test. Didn’t find one.
While it’s total conjecture on my part, I think with a vacuum secondary carb it would do ok for torque….
But the none dual port 360 tested poorly in the dyno tests. In fact, anything that says Offenhauser for an Olds run away from. The tunnel r is acceptable….
