Newly Built 455 Thrust Bearing Dilemma!!
Old Sep 22, 2025 | 09:32 AM
Saturn71's Avatar
Unhappy Newly Built 455 Thrust Bearing Dilemma!!
I apologize in advance for the long post, but I figured its best to get as much information on the table as possible. Thank you............
Last year I had a machine shop work on and build a 455 for my 1971 442 W30. The block is a 1969 casting that I picked up about 10 years ago. The guy I bought it from was going to use it for a 1969 Cutlass build, but had decided to sell the car before building the engine. My machine shop decked the block, bored it .040" over, and align honed it with the stock main caps. The crankshaft used is a Eagle 4.25" stroke crankshaft internally balanced by the machine shop with Scat rods and SRP 4032 pistons. The engine has a hydraulic roller camshaft purchased from Mark, Melling high volume pump, Morosso 7qt pan, ATI damper, Edelbrock heads, Harland Sharp Rockers, Torker Intake, ARP main studs and head bolts, 1 3/4" headers, and a throttle body efi to top it off. The engine is backed by a TH400(same transmission that was behind the original engine, which didn't have thrust issues). Torque converted used was Hughes GM25HD converter with shimmed to get between 1/8" and 3/16" spacing. Engine oil used is Driven 10w40 break in oil and Wix filters.
The engine was first ran in late May of this year for 15 minutes in the driveway 1500-2500rpm, and the oil and filter was dropped. I refilled with Driven break in oil and drove it about 40 miles(below 3000 rpm but varied) over the course of 2 days. The engine ran very well and had good power. At the end of the 2nd day I dropped the oil and my heart sank as I saw a good amount of gold glitter when tipping over the filter. My machine shop told me to check thrust clearance/movement, and with my dial gauge it showed .016" fore/aft movement. I pulled the engine, and my machinist replaced the original thrust bearing(Clevite-Mahle MS-804H) with a new thrust bearing(Clevite-Mahle MS-804P). He said the thrust surface of the crankshaft looked fine, and he filed a chamfer from the oil groove to the rear face of the thrust bearing the get pressurized oil to the thrust face. Below is a picture of the first thrust bearing with the top half being the block half, and the bottom half being the cap half of the bearing. The other side thrust surface of the bearing shows zero wear.
My machinist said the thrust issue could be caused by a bad torque converter, so I purchased a Coan 11" pro street torque converter to replace the Hughes. At this time I also decided to replace the cooler lines going from the TH400 to the Be Cool radiator from the stock 5/16" to 3/8" copper/zinc hardline to make sure there were no line restrictions. After reinstalling the engine, spacing the converter, and running it for another 35 miles, I dropped the oil and filter and saw more gold glitter when I tipped over the filter. I checked the thrust clearance again, and this time I got .011". I pulled the engine again and brought it back to the machine shop. The machinist pulled the crankshaft, checked the crankshaft for smoothness and runout, but he said everything was good. I gave him a new set of Clevite-Mahle MS-804H bearings to install and he buttoned the engine back up. He did the same thrust bearing chamfer mod on this new thrust bearing. I also dropped the TH400 off with the machinist to have his transmission guy go through it, and the transmission was given a clean bill of health. I suggested a transmission pump converter feed hole restrictor, but the transmission guy didn't think that was a good idea. Below is a picture of the second thrust bearing with the top half being the block half, and the bottom half being the cap half of the bearing. This bearing shows that the bearing was wearing unevenly with the block half wearing more than the cap half. The other side thrust surface of the bearing shows zero wear. After looking back at the first thrust bearing, the cap half also has less wear than the block half.
Thrust Bearing #2
Thrust Bearing #2
After reinstalling the transmission and engine back in the car, I installed a Derale 13960 stacked plate cooler with 10AN PTFE(all fitting upgraded from 6AN to 10AN as well) lines from the cooler back to the transmission to doubly make sure there were absolutely no cooler circuit restrictions. I know this is massive overkill, but I was getting worn down at this point and wanted to dot every i and cross every t I could. I also decided to go back to the torque converter(Precission of New Hampton 4701SS) that was behind the original engine since that engine had no thrust issues. I checked the initial thrust clearance this time before sticking the engine back in, and it was .0045". I got the car running, and once again it was running good. I decided to check the transmission line pressure against the pressures listed in the 1971 Chassis Service Manual.
In drive - brakes applied engine at 1000rpm I got 130psi, while the manual shows 60-90psi
super low - brakes applied engine at 1000rpm I got 150psi, while the manual shows 135-160psi
reverse brakes applied engine at 1000rpm I got 210psi, while the manual shows 95-150psi
neutal brakes applied engine at 1000rpm I got 120psi, while the manual shows 55-70psi
drive idle I got 115psi, while the manual shows 60-85psi
drive - 30mph coast I got 85psi, while the manual shows 55-70psi
I checked TCI and a couple other performance TH400 manufacturers, and all show line pressures exceeding 200psi for their TH400 transmissions.
I then drove the car about 35 miles, I dropped the filter, and saw more gold glitter. I checked the thrust clearance and it was .011".
At this point I'm at a loss(and tired of just throwing money at it) since the machinist said that he didn't see anything in the engine that he thought would lead to a thrust issue the last time he had the engine.
I appreciate everyone's time in reading this long post! Any ideas or suggestions would be greatly appreciated!
Old Sep 22, 2025 | 10:05 AM
fleming442's Avatar
That sucks, man, and I have no idea what could cause that other than pressure from the rear. I had a similar problem with running a manual transmission with an auto crank.
It almost sounds as if there's an issue in the converter. Ballooning?
Old Sep 22, 2025 | 10:09 AM
VC455's Avatar
Barely Registered
Your long post was very informative. No need to apologize. Long gets good input immediately. Five word posts like, "My engine won't run. Help!" tend to get ignored until ten posters pry out the information.
If there was no glitter after 15 minutes of running (installed in the car, presumably) I can see why you are focusing on the transmission.
You know you can expect expert help on CO. But if it the problem persists, consider putting the engine on a dyno.
If you choose a dyno run by capable FI tuners, you will get better running as a bonus. At a minimum, you will prove/disprove the transmission connection.
Best of luck to you.
Old Sep 22, 2025 | 10:54 AM
chuck_royle's Avatar
You need a lot of power and traction to "balloon" a convertor. Forgive me if you wrote in your story but after each fresh bearing, did you check thrust end play BEFORE you started it up? One of those pics looks like the upper and lower thrust bearings weren't lined up the same (seated).
Old Sep 22, 2025 | 11:20 AM
Saturn71's Avatar
Unfortunately I only checked thrust clearance(end play) before running the engine this last time. That measured .0045”. The machinist indicated that he shoots for an initial clearance of .003-.005”. At this point I can only assume that was where the first two thrust bearings were at before they were run. I forgot to mention before that there is no trans brake in the car and neither the Hughes or Coan converters showed any signs of ballooning. I also checked the crankshaft pilot and converters each time I installed them to make sure there was free rotation(no binding) of the torque converters before I shimmed them to proper 1/8”-3/16” clearance. The pilot looks good and there’s no material transfer which I would expect if the converter touched it.
Old Sep 22, 2025 | 11:29 AM
JerryW's Avatar
Does the "snout" of the converter fit into the hole in the crankshaft and not bottom out? How old is the flex plate? typically a thrust bearing wears when the converter ballons and pushes the crankshaft. But lots of other parts come into play. The flex plate is supposed to flex some as the converter pushes forward, hence the flex part in its name. If the snout of the converter catches any part of the crankshaft, it will wipe out the thrust bearing in a heart beat. At the OEM level we used to use a special grease on this interface to promote then not catching each other. Since you have an aftermarket crankshaft I'd look there or the flex plate itself to see if it flexes. There is a LOT more to that interface then what most people thing.
jerry
Old Sep 22, 2025 | 11:45 AM
Saturn71's Avatar
Thanks Jerry. The flex plate is an ATI SFI internal balance flex plate. The flex plate bolts are low profile 12 point ARP bolts. I double checked converter to flex plate bolt clearance to make sure there was no contact there. The pilot and converters have no contact and the converter free wheels when up almost against the flex plate before it is shimmed back for proper torque converter spacing.
Old Sep 22, 2025 | 12:19 PM
66_Jetstar's Avatar
The crank needs to be removed and checked for runout. You can also break it in next time without the converter bolted to the flexplate.
Old Sep 22, 2025 | 12:56 PM
cutlassefi's Avatar
BINGO!! That’ll narrow it down for sure!
And I can tell you from experience, the thrust on the Eagle cranks is tight, and usually not square. I always had to shave material off the thrust face when using those cranks.
Thanks.
Note; and the only real difference between a P and H series bearing is, the H is more concentric. I’ve never known them to have different thrust thicknesses.
Old Sep 22, 2025 | 01:16 PM
Saturn71's Avatar
Thanks for the comments and insight guys! The crankshaft was checked by the machine shop for runout after the second thrust bearing failure. Unfortunately the machine shop doesn’t have an engine dyno, so I will probably need to take the engine to Salt Lake City as there are none in my area. Does anyone know of a good shop in SLC that has a dyno?
Old Sep 22, 2025 | 02:47 PM
CANADIANOLDS's Avatar
your converter charge pressure is way to high. you need to install a restrictor in the converter charge feed circuit.
it’s forcing the converter into the crank..that’s why it’s showing wear only on one side of the bearing
Old Sep 22, 2025 | 03:59 PM
I have been building 400s for almost 30 years, I have done the converter restriction modification maybe 10 times, only at the customers request. Once you understand how a lockup converter works, you will realize charge pressure isn’t that big a deal.
I would dyno the engine before installation, preferably at the shop that did the assembly. If that’s not an option, use a dyno facility of the engine shop’s preference. Be sure to measure end play before and after the dyno.
Open up the transmission, make sure the end play is good. There are 2 end play adjustments, make sure the front e splay is greater than the rear endplay.
I have built hundreds of 400s with fixed line pressure of 220psi, it’s no big deal. I’d be curious to know what the line pressure is with the modulator unhooked. A stock blue 400 pressure regulator spring with 2 horseshoe shims will provide about 165-180psi, more than enough for 800hp with the right clutch count.
When you are ready to install the transmission, make SURE the converter fits up to the flexplate, and the converter pilot fits into the crankshaft pilot bore, and rotates freely.
It takes ALOT of power to balloon a modern converter, even with a transbrake. While the engine is being worked on, I’d definitely contact Coan and precision for their suggestions and thoughts.
Old Sep 22, 2025 | 04:03 PM
Saturn71's Avatar
I have always had a strong suspicion that the converter pressure could be the issue. The only thing causing me to second guess that was the fact that this same transmission caused no issues behind the original engine when that last ran 18 years ago. I’ve had the car for 28 years now. I suggested a converter feed restricter when I had the transmission looked at, but I may push harder to have one installed. The only question would be how large the restricter hole should be. I’ve read that .125” is a good starting point, but a smaller restricter could be necessary to get the pressure under control. Unfortunately it’s trial and error without a transmission dyno, which I haven’t been able to find in the Salt Lake City area. Even though Denver is further away, I would consider driving the transmission there too if there were one available in Denver. A downside of living in the middle of nowhere…..
The Derale cooler I am running is bypassing the radiator cooler entirely, as I have heard running them in series can cause further restriction in the cooling circuit.
Old Sep 22, 2025 | 04:05 PM
Saturn71's Avatar
Thanks Matt, I’ll be talking to the machine shop in the next couple days and I’ll suggest an engine dyno session.
Old Sep 22, 2025 | 05:13 PM
it’s pretty easy to do yourself. the part is about $10 or make one yourself. feed hole should be .110 to .115
while you have the trans out of the car..run the engine to see how it is on its own.
Old Sep 22, 2025 | 05:29 PM
Everyone is assuming the engine guy knows how to install an Olds thrust bearing right?
I know many don’t..even some who think they do, actually don’t.
Old Sep 23, 2025 | 05:10 AM
gear head's Avatar
Fast lane machine in Orem, UT. They are also savy with the oldsmobile platform.
Old Sep 23, 2025 | 06:43 AM
BillK's Avatar
Did anything else change on the car between the last time it ran and when you put this engine in ? Like Matt said, make sure the converter snout will go all the way into the crank until the converter hits the flexplate. You said that you shimmed the converter ???? Not sure why you had to do that ?
The only other thing was on your second set of pictures the cap side of the bearing is wearing unevenly ? The only time I have seen that in the past was when a shop align honed an engine and when they did it they cut the cap slightly crooked and the bearing was not square to the crankshaft.
I think it has something to do with the entire installation. Running it on the dyno will verify that. If you can dyno it and not have a problem then you can be pretty sure it has something to do with the converter/transmission. You probably need to get another set of eyes to look at it for you when you put it back together.
Old Sep 23, 2025 | 07:34 AM
oddball's Avatar
I've had thrust issues with certain blocks before. The #3 cap just didn't sit right, which led to uneven clearance which leads to rapid wear which leads to failure.
I'm paranoid about that now, so I do the whole dance with a dead blow hammer and pry bars to get the #3 cap lined up, and then I also check the clearance all the way around - as much as can be reached - using feeler gauges. Use a dial indicator on the snout for the real clearance reading, but use feelers to ensure the clearance stays the same as much as possible around as much of the thrust surface as you can reach. I had one engine where the thrust bearing ended up getting bent like a taco - thrust clearance at the top and bottom was half of what it was at the parting line. And that was because the block was excessively line bored, so the parting line sank into the block, and the cap didn't sit square. The cap was machined a little "odd" so the outer edge of the thrust surface ever-so-slightly hit some non-machined areas which pushed out the bearing. Also remember that you have to use lightweight oil for this - not assembly lube or grease.
It was possible to get a good lineup with that block, but it required filing down the alignment tabs and a very careful hammer-pry-tighten-hammer-pry-tighten sequence.
Long story to say that weird **** happens with old parts and it's worth spending extra time to double/triple/quadruple check things. A good machinist might breeze right over this kind of stuff because it's just really uncommon.
4 to 5 thou is pretty tight, IMO. If everything is perfect then that's a great target. But with these old blocks that might be too tight. Personally I aim for the 8 to 10 range.
Old Sep 23, 2025 | 10:08 AM
BillK's Avatar
I have never seen a little bit too much end play cause a problem
Old Sep 23, 2025 | 12:43 PM
OLDSter Ralph's Avatar
Thanks.
It seems to me that if the thrust face on the crank is not flat, square, perpendicular or what ever term you choose, correct that first.
Old Sep 23, 2025 | 01:56 PM
it’s not the age of the part that was or is the problem when it ran for decades without eating a thrust bearing. it’s what happened after some hack decided to screw it up.
Old Sep 23, 2025 | 03:32 PM
Thrust Bearing #2
Thrust Bearing #2
can you explain in more detail why you needed to shim your converter?
what was the clearance between the mounting lugs and flex plate when the converter was pushed all the way into the trans?
Old Sep 23, 2025 | 07:14 PM
Saturn71's Avatar
The shimming I was referring to was placing a washer between the converter pads and the flex plate. With the torque converter fully seated into the transmission, the gap between the converter pads and flex plate exceeded 3/16”. A grade 8 washer was necessary between each converter pad and the flex plate to get the converter spacing in the range of 1/8”-3/16”.
Old Sep 23, 2025 | 07:23 PM
Saturn71's Avatar
After installing the engine each time, I made sure there was no binding between converter snout and the crankshaft pilot by bringing the converter forward until it was nearly touching the flex plate and rotating the converter to make sure there was no binding or contact. The converters(Hughes, Coan, and Precision) all rotated freely.
Old Sep 23, 2025 | 07:34 PM
Saturn71's Avatar
I know very little about engine dynos. With the engine bolted to the dyno, will the dyno apply pressure to the flex plate similar to a transmission?
It’s my understanding that the torque converter is basically a fluid coupler between the engine and transmission and also acts to drive the transmission pump. I may be wrong, but this style of torque converter will always apply some degree of pressure to the flex plate due to the difference in surface area between the front of the converter and the back of the converter(back of the converter having an open hole through the converter drive hub). A higher converter pressure would amplify forward pressure due to this difference in surface area between the front and back of the converter.
Old Sep 24, 2025 | 04:14 AM
ok that’s correct. but does the converter pads also touch the flex plate when all the way forward without the washers?
Old Sep 24, 2025 | 05:46 AM
Saturn71's Avatar
Yes, the converter can be brought fully forward to the flex plate without the washers. There was no binding, and there was free and easy rotation, when doing this with all three of the converters I have.
Old Sep 24, 2025 | 05:59 AM
BillK's Avatar
Here is a kind of long copy of part of a Bulletin from the Automotive Engine Rebuilder's Association. AERA.org It explains some of the theory with the converter pushing forward etc.
From AERA Technical Bulletin #1465
Diagnosing the problem:
By the time a thrust bearing failure becomes evident, the parts have usually been so severely damaged that
there is little if any evidence of the cause. The bearing is generally worn into the steel backing which has
severely worn the crankshaft thrust face as well. So how do you tell what happened? Start by looking for the
most obvious internal sources.
Engine related problems:
* Is there evidence of distress anywhere else in the engine that would indicate a lubrication problem or
foreign particle contamination?
* Were the correct bearing shells installed, and were they installed correctly?
* If the thrust bearing is in an end position, was the adjacent oil seal correctly installed? An incorrectly
installed rope seal can cause sufficient heat to disrupt bearing lubrication.
* Examine the front thrust face on the crankshaft for surface finish and geometry. This may give an indication
of the original quality of the failed face.
Once you are satisfied that all potential internal sources have been eliminated, ask about potential external
sources of either over loading or misalignment.
Transmission related problems:
* Did the engine have a prior thrust bearing failure?
* What external parts were replaced?
* Were there any performance modifications made to the transmission?
* Was an additional cooler for the transmission installed?
* Was the correct flexplate used? At installation there should be a minimum of 1/16" (1/8" preferred, 3/16"
maximum) clearance between the flex plate and converter to allow for converter expansion.
* Was the transmission property aligned to the engine?
* Were all dowel pins in place?
* Was the transmission-to-cooler pressure checked and found to be excessive? If the return line has very low
pressure compared to the transmission-to-cooler pressure line, check for a restricted cooler or cooler lines.
* If a manual transmission was installed, was the throw out bearing properly adjusted?
* What condition was the throw out bearing in? A properly adjusted throw out bearing that is worn or
overheated may indicate the operator was "Riding The Clutch".
How does the torque converter exert force on the crankshaft?
There are many theories on this subject, ranging from converter ballooning to spline lock.Most of these
theories have little real bases and rely little on fact. The force on the crankshaft from the torque converter is
simple. It is the same principle as a servo piston or any other hydraulic component: Pressure, multiplied by
area, equals force. The pressure part is easy; it's simply the internal torque converter pressure. The area is a
little trickier. The area that is part of this equation is the difference between the area of the front half of the
converter and the rear half. The oil pressure does exert a force that tries to expand the converter like a
balloon (which is why converter ballooning is probably often blamed), however, it is the fact that the front of
the converter has more surface area than the rear (the converter neck is open) that causes the forward force
on the crankshaft. This difference in area is equal to the area consumed by the inside of the converter neck.
The most common scenario is the THM 400 used behind a big-block Chevy. General Motors claims that this
engine is designed to sustain a force of 210 pounds on the crank shaft. The inside diameter of the converter
hub can vary from 1.5 inches up to 1.64 inches. The area of the inside of the hub can then vary from 1.77
square inches to 2.11 inches. 210 pound of force, divided by these two figures offers an internal torque
converter pressure of 119 psi to 100 psi, respectively. That is to say, that depending on the inside diameter of
the hub, it takes between 100 to 119 psi of internal converter pressure to achieve a forward thrust of 210
pounds. The best place to measure this pressure is the out-going cooler line at the transmission because it is
the closest point to the internal converter pressure available. The pressure gauge must be "teed" in so as to
allow the cooler circuit to flow. Normal cooler line pressure will range from 50 psi to 80 psi , under a load in
drive.
Causes for excessive torque converter pressure:
There are two main causes for excessive torque converter pressure: restrictions in the cooler circuit and
modifications or malfunctions that result in high line pressure. One step for combating restrictions in the
cooler circuit is to run larger cooler lines. Another, is to install any additional cooler in parallel as opposed to
in series. This will increase cooler flow considerably. An additional benefit to running the cooler in parallel is
that it reduces the risk of over cooling the oil in the winter time-especially in areas where it snows. The
in-parallel cooler may freeze up under very cold conditions, however, the cooler tank in the radiator will still
flow freely. Modifications that can result in higher than normal converter pressure include using an
overly-heavy pressure regulator spring, or excessive cross-drilling into the cooler charge circuit. Control
problems such as a missing vacuum line or stuck modulator valve can also cause high pressure.
What will help thrust bearings survive?
When a problem application is encountered, every effort should be made to find the cause of distress and
correct it before completing repairs, or you risk a repeat failure.
A simple modification to the upper thrust bearing may be beneficial in some engines. Install the upper thrust
bearing in the block to determine which thrust face is toward the rear of the engine. Using a small, fine tooth,
flat file, increase the amount of chamfer to approximately .040" (1 mm) on the inside diameter edge of the
bearing parting line. Carefully file at the centrally located oil groove and stroke the file at an angle toward the
rear thrust face only, as shown in the illustration below. It is very important not to contact the bearing surface
with the end of the file. The resulting enlarged ID chamfer will allow pressurized engine oil from the
pre-existing groove to reach the loaded thrust face. This additional source of oiling will reach the loaded
thrust face without passing through the bearing clearance first (direct oiling). Since there may be a load
against the rear thrust face, oil flow should be restricted by that load and there should not be a noticeable
loss of oil pressure. This modification is not a guaranteed "cure-all". However, the modification should help if
all other conditions, such as surface finish, alignment, cleanliness and loading are within required limits.
Other External Problems. Aside from the items already mentioned, there is another external problem that
should be considered. Inadequate electrical grounds have been known to exacerbate thrust surface wear.
Excessive current in the vehicle drive train can damage the thrust surface. It affects the thrust bearing as
though the thrust surface on the crankshaft is not finished properly finished (too rough). Excessive voltage in
the drive train can be checked very easily. With the negative lead of a DVOM connected to the negative post
of the vehicle battery and the positive lead on the transmission, there should be no more than .01 volts
registering on the meter while the starter is turning over the engine. For an accurate test, the starter must
operate for a minimum of four seconds without the engine starting. It is suggested to disable the ignition
system before attempting this test. If the voltage reading observed is found to be excessive, add and/or
replace negative ground straps from the engine to the vehicle frame and transmission to frame until the
observed voltage is .01 volts or less. Note: Some systems may show a reading of .03volts momentarily but
yet not exhibit a problem. For added assurance, it is a good idea to enhance the drive train grounding with
larger battery cables or additional ground straps.
A special thank you goes out to Dennis Madden of ATRA, Dave Hagen of AERA, Ed Anderson of ASA, Roy
Berndt of PERA and John Havel of AE Clevite for their contributions to this article.
The AERA Technical Committee
Old Sep 24, 2025 | 07:03 AM
oddball's Avatar
Converter spacing is totally normal and expected. Aftermarket converters are intentionally made a little short because you can add washers to take up space, but a converter (or pad) that's too tall can't be fixed and will destroy parts extremely quickly. There's a bunch of different flexplate - to - trans pump depth distances, so they have to figure out something that will work for everyone. I think you're doing that correctly.
The dyno does NOT put any significant forward pressure on the engine. That's the point here. If the engine runs happily on the dyno then the damage isn't because of the engine itself. It still could be that the thrust surface isn't quite correct, hence *any* forward pressure causes failure.
For our canadian friend, that's exactly what I mean - after all these years there have been lots and lots of opportunities for someone to do interesting hacks. You never know the real history unless you bought this thing brand new, and alllllll kinds of weird **** could have been done to it over the years. I have a block where the main oil galley from the #5 cap out to the oil filter pad got hit by a cutter and had a pinhole leak that turned into a fingernail sized hole. When did that happen? No idea, but wasn't a fresh cut.
Old Sep 24, 2025 | 07:28 AM
  #31
ok, you’re all good there.
you could tee in a gauge to your cooler line to see what pressure you have there. the lower line is where you want read it.
there is a simple way to check thrust main cap parallel alignment with the block..but it’s together again …not sure you want to take it apart to check that. it is critical though because it has been line honed
Old Sep 24, 2025 | 08:19 PM
  #32
Saturn71's Avatar
I’ve read that AERA technical bulletin #1465 in the past, and that was one of the things that has had me looking at the transmission closer.
I had previously connected a pressure gauge to the cooler line leaving the Be Cool radiator transmission cooler. This was when I was still using the stock 5/16” hard line. The pressures through each gear was between 30-35psi. Unfortunately I did not take a pressure reading on the hot line going from the transmission to the cooler.
The Derale cooler’s fan is controlled from a thermostat switch that threads into a 10AN fitting at the inlet side of the cooler. I could pull that switch and thread in a pressure guage to check the transmission fluid pressure going to the cooler. With the Derale cooler having a MUCH higher fluid flow capacity(about 12 gallons per minute according to Derale at some unknown pressure that they did not disclose) than the TH400 needs, I assume the pressure will read low. But it never hurts to check.
My question regarding the engine dyno was in the hopes that the dyno did apply a pressure to the flex plate similar to what a transmission would apply. If there is no pressure from the rear, the only thing I would find out from the dyno would be if the rotating assembly was producing its own forward thrust. That would only be evident if the rotating assembly’s own forward thrust exceeded the capacity of the thrust bearing thereby wearing it. I’m assuming I could accomplish the same thing by running the engine in the car with the torque converter disconnected from the flex plate.
During the initial 15 minute run of the engine back in May, the only fluid in the transmission was about 5 quarts with an additional 1 quart in the torque converter. During this 15 minute run I assume the pressures in the transmission were very low. I did not notice any metal in the oil or filter when I dropped them after the 15 minutes. I only fully filled the transmission after the initial 15 minute run and oil change. It was subsequent oil changes after the transmission was full where I started to see metal and thrust bearing wear.
With no pressure on the flex plate, there’s no way in determining if the thrust bearing can handle reasonable pressure from any TH400, let alone the transmission I currently have in the car. What I was hoping to avoid was purchasing a different $2500+ transmission with the possibility that the engine could still have thrust bearing issues in front of a new transmission.
I’m open to any comments if I’ve said something incorrect or made a bad assumption. One again, I greatly appreciate everyone’s input.
Old Sep 25, 2025 | 05:57 AM
  #33
oddball's Avatar
No, you're correct. It's a puzzle. I would not necessarily blame the transmission at this point.
35psi in the cooler line isn't too much. That is the lube circuit, so there will be pressure. The pressure before the cooler might be a bit higher, but fluid coolers usually aren't *that* restrictive. And if you have an aftermarket one now then that's definitely not an issue (assuming it isn't damaged or manufactured wrong).
Old Sep 25, 2025 | 06:28 AM
  #34
BillK's Avatar
Not sure why you would think that it was not able to ? TH400s were installed behind 455's in production vehicles so I don't see where it should be an issue.
Old Sep 25, 2025 | 12:00 PM
  #35
Saturn71's Avatar
Thanks Bill! My reasoning for that statement is the fact that I don’t yet know if it’s an engine issue or a transmission issue. Without knowing that, I don’t think there is a good way yet in determining what the cause is beyond the effect I already know…..the thrust bearing is being destroyed.
You are correct, these engines have had TH400 transmissions behind them for decades with success. However, either this transmission is destroying these thrust bearings, or the engine is unable to withstand the thrust load from a reasonable TH400. I just don’t know which is the right answer yet.
Another possible answer is that the cause is neither the engine or transmission , but something else I haven’t found. But with everything I have read, checked myself, and discussed with people way more knowledgeable than myself, I believe the chance that it is something else is rapidly decreasing.
Old Sep 25, 2025 | 01:13 PM
  #36
BillK's Avatar
Those 2 statements contradict each other I dont think there is any issue with the engine being able to absorb the load of the TH400. There is obviously something going on but I dont think it has anything to do with the ability of the engine in front of a TH400.
I will say that I would have to question the condition of the thrust surface of the crankshaft. I know your machinist said it was "fine" but is it really ? Hard to believe it did that much damage to the bearing and didn't hurt the crank some. I am not sure there really is a good way to absolutely check the thrust surface other than putting it in the crank grinder and running up on it with a freshly dressed wheel. Only other way might be to clean it all up and put it in the block with new bearings that have been coated with machinist die so you can see exactly where it is hitting.
Hopefully they will find something.
Old Sep 25, 2025 | 01:15 PM
  #37
Did you discuss the situation with Coan?
Unfortunately, you are stuck in the middle of a pissing match. The engine builder wants to blame the transmission, the transmission builder blames the converter, and the converter builder blames it on improper installation.
I’m convinced the LS engine thrust bearing problem is the cheap converter adapters people buy to use normal old school th400 converters with newer LS engines. Dimensional, something isn’t right. It’s far better to buy a converter made for the engine. Obviously, that’s not the problem you are having, but it’s the cause of a few of the failures I have been involved with.
As long as the converter pilot fully seats into the crankshaft, and you have at least an 1/8 space between the flexplate and the converter mounting ears with the converter fully seated, I’d be willing to bet the converter install is done correctly.
Old Sep 25, 2025 | 02:56 PM
  #38
Saturn71's Avatar
Thanks Bill, I like the idea of machinist's dye....I'll suggest that to my machinist when I speak with him.
I don't see that those two statements are contradictory though. The premise of those two statements are different. One is a successful combination of engine and transmission. The other is what I have going on right now, which is anything but successful . Luckily I believe most people's experience with new engine builds is positive, otherwise I don't think anyone would be trying to get their engine rebuilt.....I definitely wouldn't. Honestly, if I could with 100% certainty pin this issue on the transmission, I would be happy! I would start saving for a new transmission and move on. All I want to do at this point is fix this issue and drive my car!
Thanks Matt, I haven't talked with the converter manufacturer's yet. It's been a busy work week, and I haven't had the chance to make any phone calls. One thing I am 100% certain on is that I've got my torque converter spacing down! I've replaced the converter enough and had the engine in and out of the car enough in the last few months to be 100% confident of that . Its tough being stuck in the middle, but what I'm trying to do is think this out. Trying to throw money at it until this point hasn't worked out, and I don't have enough money to just hand the car over to someone and pay to "get it resolved". Unfortunately I don't have Bill Gates pocket book .
Old Sep 25, 2025 | 04:57 PM
  #39
BillK's Avatar
I am not sure which way to tell you to go but I am leaning more towards an issue in the engine. You really never drove the car and I cannot imagine the converter/transmission making any force without a load on the transmission. If I had built it and was having this problem the first thing I would do is take the crankshaft to the guy that grinds them for me and tell him to make sure it is done correctly.
Is your guy completely taking this thing apart to clean all of the oil passages ? Is it possible that there is some type of oil restriction to the thrust main ?
Just thinking out loud
Old Sep 25, 2025 | 05:57 PM
  #40
VORTECPRO's Avatar
"when a shop align honed an engine and when they did it they cut the cap slightly crooked and the bearing was not square to the crankshaft"
ARE YOUR MAIN CAPS CUT ON THE FRONT OR REAR FACES?
Example:
