New Cam Timing Results
Today I Installed my lunatic hydraulic roller I bought from cutlassefi. Initially lined up the cam sprocket and crank gear dot-to-dot. After finding "true" TDC, I measured for the centerline of intake lobe. Using a Cloyes 3 piece billet true roller timing set with 9-keyway crank sprocket.
CAM card says:
Centerline of intake lobe: 109*
Intake Duration: 235 @ .050
Exhaust Duration: 241* @.050
Measured Duration
Intake: 235* @ .050
Exhaust: 242.5* @ .050
Results with crank gear @ 0*
Centerline of intake lobe: 105.5*
Results with crank gear @ 4* retard
Centerline of intake lobe: 110.75*
Results with crank gear @ 2* retard
Centerline of intake lobe: 107.25*
Leaving it at 2* retard and with chain stretch, should be about 108*
It's going to be a couple months before I get this all together and fired up. I'll keep you all posted.
CAM card says:
Measured Duration
Intake: 235* @ .050
Then take all apart part and start body finishing and painting with the engine compartment.
As as far as HP/TQ, I'm been told with the motor specs, compression, heads and cam, I should right around 500/500+.
jpc647
July 1st, 2014 02:15 PM
oldsonharmont
January 21st, 2009 05:22 AM
olds307owner
May 17th, 2007 07:48 PM
