New build
Old Oct 9, 2014 | 08:13 PM
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
New 455 build w/Edelbrock Heads
New build complete.
455 .030 over
Probe pistons
Eagle rods
Edelbrock heads
Lunati cam 241/249 .539/.555
Harland Sharp rockers
Old Oct 13, 2014 | 01:25 PM
DLaz70OLDS98's Avatar
I look forward to watching the build Dan!
Old Oct 13, 2014 | 06:14 PM
cutlassefi's Avatar
Originally Posted by 67Olds442X2
Thanks Drew. I have so much to do and the LT1 will probably be first since I have more parts for it. I got a balanced rotating assembly for $600 from Eagle for it, crazy low price. You might want to have the balance checked. They've been known to be off.
Need to send my two 455 blocks in and have them checked out, may build two. One using my original set up with new cam and heads I got and put another together using the Probe pistons, Eagle rods and a Hyd roller cam for future use. May just put the Olds off until I can get the roller cam and different fuel/intake setup instead of the Tunnel Ram. Only time will tell, guess you can say this was poorly planned.
Let me know if I can help with the cam, or anything else for that matter. Best of luck in your projects!!!
Old Oct 15, 2014 | 05:04 AM
cutlassefi's Avatar
Yes, I can get you just about anything you need. Thanks!
Old Oct 16, 2014 | 12:07 PM
I have a plan now.
Going to put the short block I was using before back together. I had the valve guide issue and flat cam lobe. I had taken my "E" iron heads in to get guides installed but both heads had cracks on the two inboard exhaust seats hence the new Edelbrocks. I have a replacement cam (Lunati 60805) to use along with the new heads. Pistons are Speed Pro's with 18cc dish. I'm going to get a Torker and run one of my 650's which might be small but I just want to get the car back on the road while waiting to do the other.
Also need to get the LT1 together and install in Corvette so I can put the engine compartment back together.
The other engine, if the block is good, will be bored for the Probe's and I'll use the Eagle rods and may get an Eagle crank. I'll get a roller cam (Lunati), put the Tunnel ram on and the Edelbrock heads. I'll work the heads a little and set them up for the new cam. Time to get started.
Funny, my wife has allowed me to spend the dough and if I don't make noise soon, need to have one car running, I'll be in trouble.
Sounds like you have a few irons in the fire Dan. Lol!
Old Nov 24, 2014 | 01:01 PM
oldstata's Avatar
Justin
Can you post pic of the area the rod hit on number 7 that you needed to clean up
Thanks Justin
Old Dec 16, 2014 | 07:13 PM
rubeng442's Avatar
About ready to fire it up this weekend. Just need to get a hold of some good gas.
455 .030 over
"N" crank .010/.010
Eagle "H" beam rods
Probe SRS Forged pistons
Zero deck
.040 Mr.Gasket MLS head gaskets
Edelbrock Heads
Harland Sharp rockers (5016)
Lunati VooDoo cam 241/249 .539/.555 (Hyd)
Twin Edelbrock 650's (for now)
Hughes 3,000 stall
Yes too much carb, some what, tunnel ram more looks than power, sure, but it will run and look cool and thats what I want
I added a couple pics of the 94' corvette i'm doing also.
Awesome!
Old Dec 16, 2014 | 07:52 PM
oldsman72's Avatar
Wow, that's some motor, congrats. Looks wicked!
If you'd be so kind....maybe a short video clip of that sucker running once she's fired-up? It would be audio ****.
Old Dec 17, 2014 | 12:48 AM
Fullsizelover's Avatar
Wow congrats looking at some serious builds!
Here a pic of my LT1 in the 96 Impala, sure loved that car.
Hope to get some pics when I redo the 455 in a couple of years.
I like that flat aluminium look, is that stock or did you repaint the heads/covers/intake on the 455?
Old Dec 17, 2014 | 09:48 PM
64Rocket's Avatar
How did you do on the intake install?
also did you have to do the install with the engine in the car?
Gene
Old Dec 18, 2014 | 03:50 AM
Dan,
The 455 is looking badass! Its about time that beautiful car gets back on the road. Pictures and videos are greatly welcomed. Great work!
Drew
Old Dec 18, 2014 | 05:01 AM
Eddie Hansen's Avatar
looks great
Wow looks great,
Old Dec 21, 2014 | 04:01 PM
Runs good, looks even better.
Old Dec 21, 2014 | 04:44 PM
Very nice Dan! It will be good to get behind the wheel of the olds girl again!
Old Dec 27, 2014 | 10:19 AM
Awesome!
Old Dec 27, 2014 | 05:18 PM
Damn Dan she sounds great! !!!!!
Old Feb 1, 2015 | 12:23 PM
Navy P-3 FE (Ret.)
I had deleted all my posts because I thought I had another rebuild gone bad but it turns out everything is working fine. Anyway I took the car out today in 48 degree weather, I have no heat and I had the windows down. It was fun.
Old Feb 1, 2015 | 04:39 PM
madmax442's Avatar
Sweet build! I'm envious! I can't wait to get mine started!
Old Feb 1, 2015 | 04:53 PM
Looks real nice Dan. Great job on getting her back on the road.
Old Feb 1, 2015 | 07:37 PM
Want me to undelete them? Glad it was nothing serious.
Old Feb 2, 2015 | 11:52 AM
Pewter442's Avatar
What did you think went so wrong that you deleted all posts?
Old Feb 2, 2015 | 06:22 PM
Navy P-3 FE (Ret.)
I thought that something in the bottom end had gave out, it made a "Chirping" sound. Read it could be bearings so I just got frustrated that another build wouldn't last. Turned out to be the "turkey" tray I put in to keep oil off the intake. I cut the intake sides off too much and it was rubbing on the push rods. Took it out and all is fine. I may put another in later on but not anytime soon.
Old Mar 17, 2015 | 06:24 PM
Navy P-3 FE (Ret.)
Couple of vids.
Old Mar 17, 2015 | 06:51 PM
Sounds awesome Dan!!!!!! Great videos....
Old Mar 17, 2015 | 07:05 PM
Navy P-3 FE (Ret.)
Thanks Drew. I was reluctant to post the one driving because it's pretty lame but earlier that day when I brought it to work a muffler decided to disconnect itself from the rest of the exhaust and was happy to get dragged along just hanging on the hanger. Anyway I had to tie it with some rope and used duct tape to get it back home. Still had it on so didn't want to blow it again.
Hope your car is treating you okay.
Old Mar 17, 2015 | 07:48 PM
Looks wicked and sounds great. Love the tunnel ram!
Old Mar 18, 2015 | 03:37 PM
Navy P-3 FE (Ret.)
Thanks. Got to take video when its running with the second carb open, whole different sound.
Old Mar 21, 2015 | 02:22 PM
Navy P-3 FE (Ret.)
Better video.
https://www.youtube.com/watch?v=a70Y...ature=youtu.be
Old Mar 21, 2015 | 04:22 PM
Awesome Dan, best kind of car ****.
Old Mar 21, 2015 | 06:08 PM
Two words Dan, BAD ***. sounds awesome and I love the view!
Old Mar 21, 2015 | 06:59 PM
  #31
Navy P-3 FE (Ret.)
Thanks guys.
I need to get my gears now and replace the 3.08's. Time for an electric pump also. Still got some carb tuning to do.
Got the corvette back together also.
Old Mar 21, 2015 | 09:57 PM
  #32
Funny story, I bought a new one in 92. Aqua with black interior, it was stunning and awesome. My wife and I had been married for 12 years and due to her unfortunate female plumbing issues we weren't supposed to be able to have children. Well, about a month after I bought it she throws this little stick on the dining room table and starts tapping her finger on it saying..."do you know what this is"? I said no... She says "it says I'm pregnant". I say go into town and buy 3 more. Well as luck would have it she was and I traded the car off. They aren't a practical family car.
I told her Gynecologist I was going to sue him for malpractice and the cost of a Vette because he said it was impossible for her to get pregnant.
Old Mar 22, 2015 | 05:14 AM
  #33
Navy P-3 FE (Ret.)
I know the feeling. I bought a new one in 88' when I was stationed in Hawaii. Midnight Blue with light blue interior. I was 28 at the time, an E-6, single, in Hawaii. I bought a lot of accessories for the car and three months later I had to deploy to Adak, Alaska. During that 6 month deployment I met my present wife and when I got back to Hawaii I had to trade in that new corvette with all the accessories and only 3500 miles on it. I had the car for 9 months and 6 of them I was gone. I ended up with a Pontiac Grand Am and in a sense, a new wife.
Old Mar 22, 2015 | 06:31 PM
  #34
Navy P-3 FE (Ret.)
Sunday drive.
Old Mar 23, 2015 | 04:09 AM
  #35
tru-blue 442's Avatar
Old School Olds
Thanks for the ride alongs Dan. I could tell you were itching to open her
up a little on that last run. Very nice, she sounds great.
Old Mar 27, 2015 | 07:20 PM
  #36
Navy P-3 FE (Ret.)
Thanks. Adjusted carbs again just waiting for good weather to check it out.
Old Mar 27, 2015 | 07:30 PM
  #37
Old School Olds
I'll be looking forward to riding along when you get the chance to open her up some. That is one bad-azz ride fella.
Old Mar 28, 2015 | 03:00 PM
  #38
Navy P-3 FE (Ret.)
Another video. The part of the video where it skips my iPhone flew to the back seat.
Old Mar 28, 2015 | 04:11 PM
  #39
This is fun, lets go for ice cream.
Old Mar 28, 2015 | 08:17 PM
  #40
Old School Olds
Sweet. Looking forward to highway run. Thanks for posting.
