Need some Help with Brackets and Pulleys
Old Mar 30, 2020 | 06:00 AM
69Chrgr's Avatar
Hello Again
Could someone shoot me some pictures of their 1967 442 400 engine pics detailing the bracket arrangement? Also the correct pulleys? This is a Non-A/C car. Trying to dress out the 455 to the 1967 400 arrangement for customers 67 442.
Thanks As Always!
Old Mar 30, 2020 | 06:08 AM
66SportCoupe's Avatar
3 groove pulleys do not go on a non A/C car. Should be 2 groove lower pulley and either a single groove top or 2 groove top. Does it have power steering?
Old Mar 30, 2020 | 06:28 AM
There are a number of problems I can see. First, the 1967 cars did not use a notched valve cover on the passenger side, only on the driver side. The HVAC box on the 64-67 cars is different from that on the 68-72 cars and did not require a notch. If you're trying to dress the motor to look like a 67 442, that needs to be changed.
Second, you have a crank pulley for a 6.1" water pump, but you obviously have a shorter pump on that motor, which is why the don't line up. Once again, mixing and matching pulleys, brackets, and pump will lead to questions like this. A 1967 442 uses a 5.1" water pump for both A/C and non-A/C applications. The correct water pump pulley is P/N 390207 (code JE) for a two groove pulley. The correct crank pulley is 390206 with a JA code.
69Chrgr's Avatar
Thanks 66SportCoupe! Yes it does have power steering.
Old Mar 30, 2020 | 06:33 AM
Joe is correct about the valve cover too. Notched only on drivers side for larger power brake booster in 1967.
Old Mar 30, 2020 | 06:34 AM
69Chrgr's Avatar
Thanks Joe! That's why I come here, for this info. Thanks a million!
Old Mar 30, 2020 | 06:37 AM
69Chrgr's Avatar
Does anyone have any pics I could look at?
Old Mar 30, 2020 | 06:47 AM
Old Mar 30, 2020 | 06:49 AM
Old Mar 30, 2020 | 06:54 AM
Note how much shallower the crank pulley is. I should also add that these pulleys assume that you are using the 1967 style PS pump bracket that mounts above the valve cover on the driver's side.
Old Mar 30, 2020 | 06:59 AM
69Chrgr's Avatar
Thank You Thank You Thank You!! Exactly what I needed!
postw30man
Jan 8, 2020 09:32 AM
Christopher Michael Drew
Jun 27, 2019 08:25 PM
matt506
Jun 12, 2019 07:31 AM
crazy'boutOlds
Sep 7, 2011 07:34 PM
sammieolds
Aug 29, 2010 03:20 PM
