need help finding a part
Old Jan 23, 2011 | 07:39 AM
Alvin's Avatar
I Have a 73 olds ninety-eight and starting to restore and i broke a part which i believe is a temperatue vacuum switch or thermal vacuum switch checked everywhere. any suggestions
Old Jan 23, 2011 | 07:51 AM
2blu442's Avatar
I think I know what your describing, but to make sure can you post a picture of the broken part? John
Old Jan 23, 2011 | 08:11 AM
jaunty75's Avatar
I have a '73 Custom Cruiser, which has the exact same engine as your car. I believe I know just what part you're talking about as I needed a new one for my car as well
The service manual calls it a "thermal vacuum switch." Autozone has them for $25.00. They call it a "ported vacuum switch." (Photo below.) It's a drop-in replacement. If you go to a store, they'll order it as the website shows it as a special order item. You'll get it in a couple of days.
Old Jan 23, 2011 | 10:57 AM
Alvin's Avatar
ok i have a ported vacuum switch it's the part that feed off the ported vacuum switch it has tvs 413429 on it with two ports coming off of it . one i believe going from carb to ported vacuum switch.
Old Jan 23, 2011 | 11:14 AM
jaunty75's Avatar
OK, I think I know what you are talking about. It's called the "Distributor Thermal Check and Delay Valve" and it goes in the vacuum line between the middle port of the thermal vacuum switch and a port on the carburetor.
In my experience, this part is not made now, and no parts supplier I've searched or checked with has it. If yours can't be used, and you can't find either a good used or NOS piece, your only option is to simply run without it and hook the vacuum line directly from the tvs to the carb.
I'm not sure exactly what the "DTCDV" does. The thermal vacuum switch itself is designed to help the engine run cooler when the coolant temperature is high. What happens is that, when the coolant temp is high (the manual says 226 degree F), the valve opens, directing full manifold vacuum to the distributor vacuum advance. This advances the timing, allowing the engine to run cooler. Given its name, I'm guessing the "Distributor Thermal Check and Delay Valve" makes sure that vacuum only goes one way? Isn't this what a check valve usually does? Prevents back flow?
Anyway, like I say, I've run without one for a year now, which is as long as I've owned my '73, and I haven't had any problems. Based on the fact that, when I got the car, it not only didn't have one of these check valves but also didn't have a working thermal vacuum switch, I'm guessing it was driven for I don't know how many miles in this condition with no apparent problems.
justintiime
Sep 10, 2014 08:30 PM
rhett838
Body work
Apr 16, 2014 09:04 PM
the_onlyclw
Mar 8, 2007 03:04 PM
Razorback1974
Jan 20, 2007 07:20 AM
