Need help with cam specs
Old Nov 22, 2015 | 08:04 PM
nj_cutlass72's Avatar
I need to figure out the cam specs for the cam that I removed from my 455 but doesn't seem like the markings and the catalog of manufacturer match
http://camshaftmachine.com/wp-conten...2015-01-30.pdf
Any ideas or leads would be appreciated.
Ed
File Type: jpeg
Old Nov 22, 2015 | 08:06 PM
Pic 2
File Type: jpeg
Old Nov 22, 2015 | 08:08 PM
Pic 3
File Type: jpeg
Old Nov 23, 2015 | 02:40 AM
svnt442's Avatar
My guess would be the second one because the first one is under .400 net lift at the valve and unless this was just a cruiser with a kitten purring idle, I can't see that one being used.
The third and fourth ones would be more on the exotic side and you'd have more of an idea if it was one of them.
Old Nov 23, 2015 | 06:06 AM
thx!
Im thinking of calling the manufacturer, hopefully they wont give me some BS that its outdated or something else.
It does seem beefier vs stock but im no expert and who knows if the catalog has new items and this particular cam is discontinued?
At the end of day I need to figure out what stall convertor to go with, the rear diff is 3.42.
Old Nov 23, 2015 | 06:14 AM
svnt442's Avatar
Originally Posted by nj_cutlass72
thx!
Even if it were outdated, cam companies keep records of the camshafts that they manufacturer and it shouldn't be anything for them to pull up the specs, unless it's some sort of custom grind. And even then they might have records of it.
Old Nov 25, 2015 | 09:15 AM
I called CMC and they stated its not theirs and most likely CWC but they only provide cores.. I checked the websites of comp cams, edelbrock, erson, lunatic and the 3 digit code does not jive with any... I may end up taking it to a local shop for them to measure it to let me know what it is and how it will perform with my set up. I have 30 over block, stock heads and Pistons, stock lifters, stock intake , 3.42 rear I may end up getting a new cam just don't which one would be good selection for the street. Not looking to race anyone but I'd want to have some power to smokes tires and enjoy some throaty engine sound while I cruise top down.
Old Nov 25, 2015 | 09:19 AM
svnt442's Avatar
What heads and pistons are you using? That will dictate much of what you can run for a cam. The car weight is around 3800 lbs and you are using 3.42 gears and what stall? How tall are your tires?
All of this information plays a roll in selecting the correct cam for your application.
Old Nov 26, 2015 | 07:00 AM
the heads will be stock G heads, the rear is 255/60R15 / front 235/60R15, i have a stock stall now but I will buy a new one based what is needed;
Old Nov 26, 2015 | 07:03 AM
the block is over 30, here is a pic on the piston; it should be a performance piston head?
File Type: jpeg
Old Nov 26, 2015 | 12:08 PM
svnt442's Avatar
That is a low compression piston and will limit what you can use for a camshaft. If you want to make any kind of power you're gonna want to swap out the pistons to bump up the compression.
Old Nov 26, 2015 | 04:58 PM
say it aint so... was not looking into swapping out the piston heads.
Im planning on doing a light overhaul on this particular engine so the budget is an issue; I may tough it out with these pistons although compression may be on the low end.
Old Nov 27, 2015 | 08:38 AM
the piston heads are speed pro 2278p; you sure they are low compression?
http://www.442.com/tech/rocketattack.html
http://www.hotrod.com/how-to/engine/...-build-combos/
Old Nov 27, 2015 | 08:45 AM
svnt442's Avatar
Yes. The L2323f are the 10:1 piston.
The second link you posted was for a small block chevy build with TRW L2278 pistons. A completely different application.
Old Nov 27, 2015 | 09:00 AM
i think i found the cam info, part # 167
http://www.federalmogulmp.com/en-US/...-%20CS167R.pdf
Old Nov 27, 2015 | 09:07 AM
theres olds specs when you scroll down
WoofWagon
Apr 30, 2012 01:08 PM
jrblanke
Aug 7, 2011 08:19 AM
Olds92
Oct 26, 2010 06:41 PM
TripDeuces
Jun 16, 2010 11:09 AM
jlrichcreek
May 7, 2008 07:01 PM
