Mondello vs CompCams
Old September 21st, 2017, 06:39 PM
JK1976Olds's Avatar
I'm rebuilding my 455 with a hydraulic roller cam and wanted thoughts about Mondello vs Comp cams. I previously had the JM22-25-10 from Mondello and loved it. Mondello has a couple of hyd rollers with the same power range 1400-6000 that I'm interested in and Comp only has 2 choices and I'm not sure I'm crazy about either. Any thoughts?
JK1976Olds is offline
Old September 22nd, 2017, 04:13 AM
cutlassefi's Avatar
I do a lot of cams for guys here and elsewhere. Let me know if I can be of help.
cutlassefi is offline
Old September 22nd, 2017, 08:49 AM
Gary
VC455's Avatar
I've had an Engle (Mondello) RH95-96 in a 10.1 cr 455 for about 12 years. It has the (so-called) idle of a 1970 4-speed W-30 but it does have power. I had to install an electric vacuum pump for my power brakes.
Just a note to give you a point of reference on their hydraulic rollers.
VC455 is offline
1964F85
November 13th, 2019 08:40 PM
Mr. King
June 12th, 2019 08:14 AM
JK1976Olds
October 4th, 2017 04:00 AM
68 D88
May 13th, 2017 11:52 PM
Bluevista
Vista Cruiser & Wagons
15
October 17th, 2014 05:04 PM
Quick Reply: Mondello vs CompCams
