man seeks r&r tips for oil fill neck
Old Nov 11, 2013 | 07:23 PM
ReallyWildStuff's Avatar
Hello -
I'd like to remove the leaking oil fill tube on my 455 and re-install it in a non-leaking fashion. I'd appreciate any tips re: either the removal or the re-install.
I recall that when I built this motor I put red Loctite on the bottom of the fill neck and used a hammer and a piece of 2x4 across the top of the tube to hammer the fill neck as far into the timing shelf as far as I could get it - not nearly enough, as it turned out, as the neck can be rocked back and forth with light hand pressure.
Thank you -
Brian Ammons
Old Nov 12, 2013 | 06:21 AM
bigoldscruiser's Avatar
2 '66 98's
Since it is rocking back and forth, do this and pull upward at the same time. It should come right out. When re-installing, lightly coat the lower surface with black RTV and tap in as you did originally. It should go in about 1 1/2 inches and not rock.
Old Nov 12, 2013 | 11:15 AM
oddball's Avatar
It's not uncommon to cut 1/16 to 1/8 inch off the bottom of the tube so it's crushing fresh metal.
Octania
Apr 21, 2015 05:14 PM
Octania
Jun 22, 2013 12:22 PM
Octania
Jul 2, 2012 03:52 PM
Octania
Jun 17, 2012 05:56 PM
Octania
Mar 13, 2012 07:48 PM
