Mahle headgasket
Old Aug 12, 2022 | 10:59 AM
jskorz's Avatar
Mahle headgasket
Stupid question , while taking inventory of parts ordered for my 455 + .030 build I checked my Mahle headgaskets part #55047 and the package label reads 4.200 x .040" . Looking on Jegs website no other Mahle headgasket for 455 listed , would this be the correct headgasket even though the bore is 4.155 ?
THX in advance
Old Aug 12, 2022 | 11:16 AM
Head gasket bores are always larger than the cylinder bore, if that’s what you were wondering.
Old Aug 12, 2022 | 02:26 PM
^^^THIS. If you had bored that 455 0.060, the bore would be 4.185, so 4.200 makes perfect sense. Just don't try to use it on a 403. (Hint, the stock bore on a 403 is 4.351)
Old Aug 12, 2022 | 06:03 PM
cutlassefi's Avatar
THX in advance
Good gasket but they do require a certain finish on the deck and heads. Were those surfaced?
Old Aug 13, 2022 | 10:08 AM
jskorz's Avatar
Yes the block was decked and the heads are new Pro comp .. Thanks for the responses ..
jfb
Apr 12, 2014 08:54 PM
crank shaft
Feb 17, 2014 06:56 AM
70cutty
Feb 14, 2014 12:36 PM
John Hancock
Dec 10, 2013 07:30 AM
brandon 455
Nov 12, 2013 09:07 AM
