looking for suggestions
Old September 19th, 2017, 07:42 PM
edzolz's Avatar
I have a 425 that was rebuilt in 1986. Never off of the stand since then. I disassembled the block and when I pulled the heads and there is an area of rust along the outside edge, along the water jacket surface. I need to have the block surfaced but one of the head alignment pins has been welded in the block. If I drill this out to have the block surfaced, can I install the head with only one alignment pin and be sure the head is aligned?
edzolz is offline
Old September 21st, 2017, 06:18 AM
edzolz's Avatar
Anybody have an idea??
edzolz is offline
Old September 21st, 2017, 06:39 AM
Gary M's Avatar
I would check with a good engine build shop to see what could be done. Post some pictures on here so others can see the issue.
Gary M is offline
Old September 21st, 2017, 07:25 AM
wr1970's Avatar
Let the shop remove it!
wr1970 is offline
Old September 21st, 2017, 08:29 AM
Gary M's Avatar
X2^^^^
They probably done it lots of times.
Gary M is offline
Old September 22nd, 2017, 05:32 AM
edzolz's Avatar
Originally Posted by edzolz
welded in the block
This is the problem. It cannot be pulled out like a normal pin.
edzolz is offline
Old September 22nd, 2017, 08:25 AM
Gary M's Avatar
Most engine rebuild shops have seen that before. Call and talk to one. May not be a big deal for them.
Gary M is offline
MyPaceCar
Suspension & Handling
April 22nd, 2012 07:13 PM
RAMBOW
January 12th, 2012 08:25 PM
2fast88
November 10th, 2009 06:40 PM
elwood565
Ninety-Eight
May 8th, 2009 04:15 AM
Jeffemac
June 1st, 2007 11:37 AM
Quick Reply: looking for suggestions
