Looking for a Olds Rocket 455
Hi guys, I am looking for a 1969-1970 good core rebuildable Olds 455 Rocket complete engine in California zone. I'm in a budget build, so the engine should be 0-600$ maximum, I will pay shipping.
So the engine should be from 1969 to 1970 Olds Rocket 455, a good core rebuildable engine.
Please who have or know someone that have one for sale send me the name plus full address and asking price, some pictures and block + heads numbers.
You can email me at bassemabouantoun@hotmail.com
Thanks for the help.
Why so specific on the years? If you are looking for certain heads those can be added easily to any 455 block. If you are looking for one for a stick, then that makes sense, but again you are a bit narrow on your search.
Also what part of CA are you in?
I am looking for a genuine 455 Rocket HO
OK, if you are going to rebuild it then it doesn't matter what year the block is unless you are specifically looking for one for a manual trans application. The later block don't have the boss cast in for the Z-bar ball and would need either an adapter plate to make it work or the use of a hydraulic clutch.
So with that said, all 455's are a good foundation for a performance engine. You can use heads from any year BBO to get what you're looking for, or even go with aftermarket aluminum. It just depends on what you are looking to get out of the engine.
There will be nothing on the block to identify it as a "455 Rocket HO" as you put it.
The factory dropped the compression after the 1970 model year, but as I said, if you are going to rebuild it, that doesn't matter.
1968 and 1969 engine will have the same possible options and then in 1970 they changed the heads a bit.
Just because you look for a certain year engine doesn't mean you will get a high horsepower engine right off the bat, and in the end it won't matter.....back to you're going to rebuild it anyway.
And your location will help tons with finding you an engine that is in good shape for a rebuild.
Svty 442 , maybe you can answer a couple questions for me , I have a 455 pretty much stock . It's a 70 442 but I have a 75 block in it . Any way I can improve the HP on the motor to make it like a 70 engine ? Engine now runs great , has some ***** but not enough . Let me know
I ran a 13.89 @ 97 MPH with a 2.56 gear in the car. With a good gear that car would probably have been in the 12's.
TRW is now SpeedPro
I had a 73 block that I built about 22 years ago with J heads. I used +.030 TRW replacement pistons for 1970 and had a larger cam(.504/504 296°/306° 228°/235°) then came in 70. Edelbrock performer intake and 1407 750 CFM carb and Flowtech headers with a Flowmaster 2½" exhaust system in a 70 Cutlass.
TRW is now SpeedPro
TRW is now SpeedPro
If I were looking for a rebuildable 455 for a performance application that would use the factory iron heads with no port work, anything from 1968 to 1972 with C, E, G, or GA heads would do. '73-'76 J heads would work equally well if I wanted to do some port work.
I agree with this. If I had better heads on mine it would have been even better, but I ran what I had. As it was the car was a tire fryer. 600' long posi burnouts in parking lots was as easy as stomping the go pedal to the floor. (no brake stand)
I had a 73 block that I built about 22 years ago with J heads. I used +.030 TRW replacement pistons for 1970 and had a larger cam(.504/504 296°/306° 228°/235°) than came in 70. Edelbrock performer intake and 1407 750 CFM carb and Flowtech headers with a Flowmaster 2½" exhaust system in a 70 Cutlass.
TRW is now SpeedPro
TRW is now SpeedPro
Others here will tell you the gear ratio will make a difference. You need to get more info on that before you jump into a rebuild or motor change unless the motor needs it. Even if you dump a boatload of money in the motor a weak gear may disappoint you. There are a few members on here that specialize in differentials. You ask a gear question and they will help.
the whole car was on the dyno, so it's a chassis dyno. Engine dynoed 4 months ago numbers were 530 hp and much more torque. Frankly, the engine is a 464 buick (.040 bored 455) with stage 1 aluminum TA Performance heads and TA solid cam, TA SP1 intake, holley 870 carb...
So, just to clarify, you have a running, built Buick 455, recently dynoed at approximately 470hp/540tq, in the car now, but are looking for an Olds 455 to do a budget rebuild on to replace the Buick motor.
If the Buick motor is pulling that hard... Why?
You can check the comments to see how we moved from a subject to another
Ctott70
Dec 16, 2010 06:12 PM
