Lighten a 425 Crank
Old Oct 31, 2013 | 10:57 AM
Old Olds Fan's Avatar
Question Lighten a 425 Crank
I would like to build a lightened reciprocating mass 425, I will keep the forged crank and the 3.975 stroke, new rods, custom pistons. I have seen that the 455 crank has holes drilled in the rod journals, to lighten the reciprocating weight. Is there a reason that this same machining can't be done to the 425 crank? Does anyone know which is the lightest 7" rod steel available? Any other input? (this was also posted on Tech Editors page, incorrectly)
Old Oct 31, 2013 | 03:32 PM
cutlassefi's Avatar
Unfortunately there aren't many aftermarket 7.00 rods available, light or not.
But oddly enough even the Scat rods are lighter than the stockers. Diamond is now offering a nice light forged piston as well, let me know if you need help there.
And yes you can drill the rods throws, all of them. But the ones on the ends will make the most difference in the balance. But make sure you watch out for the oil slots, they run a bit off center.
Bernhard
Nov 24, 2022 09:12 AM
steve walker
Dec 17, 2019 12:32 PM
Old Olds Fan
Tech Editor's Desk
Oct 31, 2013 09:24 AM
Bernhard
Jan 6, 2013 09:27 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
