Intake gaskets needed
Old Mar 7, 2024 | 12:51 PM
72455's Avatar
1972 U code Supreme
Hey all I'm looking for a set if intake gaskets for my '72 U code Supreme with an Edelbrock Performer intake. It has the crossovers so I'll need a set made for those. Or, do I need the crossovers and I can just block them off and use regular gaskets?
Old Mar 7, 2024 | 01:24 PM
sysmg's Avatar
A gasket blocking off the crossovers will burn through in a short while. You can get the turkey tray gasket as was used by the factory (one version for SB 350 a different version for BB 455) or you can go with fiber gaskets. Both work. I use the factory turkey tray.
Old Mar 7, 2024 | 01:25 PM
72455's Avatar
1972 U code Supreme
Do the fiber gaskets have the slots for the crossover?
Old Mar 7, 2024 | 01:30 PM
Some do, some don't.
Old Mar 7, 2024 | 01:33 PM
72455's Avatar
1972 U code Supreme
I've been looking and all the ones I've seen don't have the slots. Any leads?
Old Mar 7, 2024 | 02:53 PM
Looks like with the limited offerings now, you have to cut your own crossover port holes or drill a 1/2" hole in the gaskets. When I was a kid some came cut or drilled. Edelbrock used to supply plugs with their manifolds, the said it was to prevent damaging the manifold due high heat at WOT.
Old Mar 7, 2024 | 07:12 PM
One time I used the composition gaskets with no crossover port, and when I pulled the intake a while later the gaskets were burned through. So don’t sweat it, use them as-is and know they will burn through in a short time, or use the old gasket as a template and cut a hole in the new ones. Or use the metal style that is made with the crossover hole.
Old Mar 7, 2024 | 07:46 PM
FStanley's Avatar
Just cut out the crossover slot with a Stanley Knife if it is a fiber gasket like Mr. Gasket..
Place the gasket on the head and cut it out.
Fred
Old Mar 8, 2024 | 07:27 PM
72455's Avatar
1972 U code Supreme
Fred
Yea...that's what I think I'll do.
76cutlass
Jan 19, 2024 06:37 AM
HarrySlother
Oct 17, 2021 12:17 PM
Lars
Non-Olds Engines
Feb 15, 2015 05:34 AM
808olds
Oct 26, 2010 03:59 PM
Kidcutty
Mar 25, 2010 09:29 PM
