Intake End Rail Gaps ?
Old Aug 12, 2017 | 01:32 PM
gbledsoe3's Avatar
First timer here and asking if these gaps between the block and Intake are ok or if they seem to be too big. I have the head-to-Intake gaskets in place (dry). I also have Intake bolts on the four corners to ensure alignment. Is so, then I plan to use a bead of black RTV across them.
Here are pictures of the front and rear, both about the same.
Front
Rear
Old Aug 12, 2017 | 01:59 PM
That looks to be a normal gap that will close a little when the intake is torqued down. RTV is the approved method according to Ebrock.
Old Aug 12, 2017 | 02:04 PM
gbledsoe3's Avatar
Ok being my first time that's what I was hoping to hear. Many thanks to you and the ClassicOlds community.
Old Aug 13, 2017 | 03:48 PM
Two bits of advice. Use Permatex Ultra Black (I got the stuff in the aerosol can) and be sure to make the bead extra tall. You'll be hating life if you don't make the bead tall enough and find an oil leak after everything is torqued down.
Do NOT ask my how I know this...
Old Aug 14, 2017 | 07:10 AM
wr1970's Avatar
Also put a bead around water connection where the intake gasket and heads mate both sides on install. Don't ask what happened to me the first time i didn't do that.
Old Aug 14, 2017 | 11:20 AM
gbledsoe3's Avatar
Both sides of the gasket?
Old Aug 14, 2017 | 04:09 PM
Gerald Nickels's Avatar
Where the rubber gasket would seat use a punch across the top to give the sealant something to hold on and let set over night.
Old Aug 16, 2017 | 04:30 PM
cdrod's Avatar
Rodney
^^ X2 on punch suggestion. Will help keep the silicone in place.
Old Aug 16, 2017 | 06:00 PM
RandyS's Avatar
Has anyone tried to seal a small leak in the rear gap after the manifold is installed?
Old Aug 16, 2017 | 06:27 PM
wr1970's Avatar
Yes and i got it to seal. I used carb cleaner to clean the area. I then went with a very wide seal coat and thick. X3 on the punch method.
65Delta
Jun 8, 2014 02:11 PM
dc2x4drvr
Body work
17
Apr 5, 2014 06:55 PM
JuzCallMeDee
Body work
Feb 27, 2013 07:15 AM
DENT
Aug 23, 2012 07:06 AM
Del70
Jul 7, 2011 09:35 AM
