How to tell if car is 455 or not
Old March 27th, 2019, 09:36 PM
daddybx's Avatar
Hi Guys,
Got me a 1970 Cutlass Supreme 2 DR holiday. How can I tell if it has the 455 motor? is there an easy way? The VIN does not help. Any suggestions?
I have attached a pic of my car
Don
daddybx is offline
Old March 27th, 2019, 10:15 PM
The easiest way to tell is to look at the block casting number on the shelf above the water pump.
This is the 455 block casting number.
Fun71 is offline
Old March 28th, 2019, 05:46 AM
scrappie's Avatar
Did you buy the car not knowing what engine was in it or do you think the previous owner is wrong or didn't know? Like fun71 said about the number and also 455 eng were blue from factory otherwise it would be gold for a 350 unless repainted of course. The cylinder heads will have letters on the bottom left corners opposed to numbers for the 350. There are other ways to tell also but this should verify. Show us a pic.
scrappie is offline
Old March 28th, 2019, 07:04 AM
Well, actually, the ONLY way to tell is by looking at the casting number... (well, without disassembling the motor or using a displacement tester).
By the way, that displacement tester tool is only $1,100. I'm thinking I'd look at the casting number.
https://www.speedwaymotors.com/Speed...-Tool,703.html
joe_padavano is online now
Old August 6th, 2019, 10:26 PM
daddybx's Avatar
Yes its a 455 Motor original to car and tranny matches . I traded a boat for it so I did pretty good I have added from Disc to car Deleted the non working AC system ( will be adding VIntage Air) Nice set of centerline rims a new Aluminum 4 Core radiator. New exhaust had to return the Hedders as they would not fit ended up resurfacing the Manifolds and running 3" exhaust . Thanks for feedback
daddybx is offline
Old August 7th, 2019, 05:40 PM
72 Olds CS
RetroRanger's Avatar
Originally Posted by daddybx
Hi Guys,
Don
Your VIN should have a U or a V in it if the engine original to the car was a 455
RetroRanger is offline
Old August 7th, 2019, 09:29 PM
vette442's Avatar
If it was a 1972. His car is a 1970.
Terry
vette442 is online now
Old August 8th, 2019, 05:32 PM
72 Olds CS
Right i didnt see it was a 70...
kelo80
June 6th, 2019 09:16 AM
KevinK7
May 19th, 2018 04:14 PM
jayarty
January 12th, 2011 04:55 PM
semper-fi
December 22nd, 2009 12:45 PM
tuellbox
December 17th, 2007 04:48 PM
Quick Reply: How to tell if car is 455 or not
