Holley carb trouble
Old Jul 5, 2011 | 07:12 AM
mauls's Avatar
Green Horn
Holley carb trouble
Fired up a buddies car that had sat for 5 years. We added fresh fuel, soem sta-bil, primed the carb and finally got it running. After about 30 seconds, fuel started pouring out of the bowl vents
Fuel is blowing out of the Bowl Vent (one located closest to the driver) Any way to repair this?
Old Jul 5, 2011 | 08:06 AM
72 cutlass455's Avatar
Sounds like the float may be stuck. Old fuel left in the bowl can turn to tar like stuff that holds the float down. good luck with it.
Old Jul 5, 2011 | 10:21 AM
Rickman48's Avatar
Just had the same problem with a '76 Lincoln w/a 460 - replaced the needle and seat and solved the problem.
Worst thing was the old gaskets stuck badly, and the crossover tube o rings fell apart!
Unless you've someone to rebuild it, you're better off replacing it - not a big difference in money, and much quicker, by the time you're done.
Old Jul 5, 2011 | 10:30 AM
Rickman48's Avatar
After looking at the picture - if your lucky enough to see a colored gasket between the bowl and jet plate, those are non-stick gaskets and can be re-used!
Pull-off the bowls and squirt the needles and seats with carb cleaner until they're free - blow them out with air, and re-assemble.
Do them one at a time, and wear eye protection, too.
pinky3034
Jul 9, 2011 06:57 AM
KathleenF
Jun 4, 2011 10:29 AM
kenny
Mar 23, 2011 10:45 PM
