Holley Carb Rebuild
Old Mar 25, 2012 | 04:03 PM
Magna86's Avatar
Holley Carb Rebuild
Well I go my carb rebuild kit for the Holley 4165 spreadbore I have. But what I don't have are instructions! So does any one have some they can post or scan and email me? Never rebuilt a car carb just some of my motorcycle ones. I have no worries in my doing it just need directions for guidance. Would like to tack this tomorrow before work. Also any tips/tricks are welcome as well!
Old Mar 25, 2012 | 04:09 PM
coppercutlass's Avatar
Chevy budget Olds powered
use your part number on summitracings website and you can find the pdf file and download it .
Old Mar 25, 2012 | 04:10 PM
Oldsmaniac's Avatar
I would say the instructions are just for the settings. The rebuild is straight forward and less linkages than a rochester. Some Holleys have idle mixture screws that go rich when they are turned in. Usually turning in the screws leans it out...
Old Mar 25, 2012 | 04:25 PM
Magna86's Avatar
Well I'm sure I can take it apart but want to makesure nothing is missed cleaning/replacing parts.
Old Mar 25, 2012 | 04:41 PM
bigD's Avatar
check their website, they have a whole section of pdf downloads...
Old Mar 25, 2012 | 04:42 PM
Magna86's Avatar
Was there only found installation instructions and specification pdf's.
Old Mar 25, 2012 | 04:51 PM
compedgemarine's Avatar
what is the list number on your carb?
Old Mar 25, 2012 | 04:54 PM
Magna86's Avatar
Its a 6210-3
Old Mar 25, 2012 | 05:16 PM
see if these help
http://www.holley.com/data/TechServi...ded%20View.pdf
http://www.holley.com/data/Products/...199R8020-3.pdf
Old Mar 26, 2012 | 09:52 AM
allyolds68's Avatar
If yours is the same as mine (6497 spreadbore, mechanical secondaries)make sure you set the float level
I didn't & it was dumping fuel in. It was an easy fix but it's a lot easier to do when it's on a bench
Old Mar 26, 2012 | 10:16 AM
Oldsmaniac's Avatar
One nice thing about a lot of Holley carbs is that float adjustment can be made with engine running and bowl sight plugs removed.
Old Mar 26, 2012 | 10:24 AM
allyolds68's Avatar
I'm pretty sure I had to bend the float bracket but mine is an antique.
Old Mar 26, 2012 | 05:36 PM
Magna86's Avatar
Well mine is not that nice as it has not bowl sight plugs! Got here apart today and currently soaking in a PIne Sol bath for the night. Wasn't real dirty but found some shiny grit in the front fuel bowl. Found one broken plate guide pin. Some pics in my MAW thread. Wasn't too bad we'll see how the degreasing/clean go tomorrow. ;-)
ramrod31
Jun 15, 2013 04:44 AM
delta881972
Jan 24, 2009 05:54 AM
Wasted
Jan 19, 2009 07:53 PM
