harmonic balancer diamter
The small block and big block use the same balancer from 1968 into the late1970's at least. The diameter measured across the face where the pulley mounts is 6 1/2". Is that what you needed?
John
John
The W31 unit also has much more overall fore-aft width.
Other than that, the era uses mainly the same simple outer ring damper for all the V8's
John
