Fuel Pump Replacement.
Im in the middle of a a carb and intake swap and thought its probably a good time to change the fuel pump as well. I have a holly fuel pump but it doesnt have the fitting for the fuel return line,can I still use this pump or do I need a different one? Thanks.
Every Holley pump I've ever seen has provision for fuel return, but that port may have a plug if it wasn't used. In any case, you can use the pump without fuel return. Just cap the line going back to the tank. Fuel return is a good thing to have, however, to avoid fuel percolation, particularly with today's ethanol-loaded gasoline.
dfire25
June 28th, 2016 01:37 PM
