flowtech sbo headers on bbo?
Old Jan 19, 2014 | 02:55 PM
deltathunder's Avatar
There is a good deal for g body flowtech headers on craigslist. After my research it seems like with most brands most cars and most motors the clearance won't be correct. The car is and 84 delta 88 coupe and the motor is a 76 455, has anyone used sbo headers on a similar application? Don't worry about disappointing me. It seems like hope is lost on this one
Old Jan 19, 2014 | 04:35 PM
They may interfere with other parts of the car and they may not hang low enough. The deck height is different between a SBO and a BBO.
Old Jan 19, 2014 | 06:09 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
You need hedman 58150 . Perfect fit in an 80's delta.
Those flow tech headers are junk in my opinion.
Old Jan 19, 2014 | 06:17 PM
Oldsmaniac's Avatar
My brother put a 455 in a 77 Cutlass. We had an old set of hookers for the A body and we tried them. They fit perfect. So he went to the speed shop and bought a set of alumacoat headers. We mangled the crap out of em and got then to work....turns out they were 350 headers. !!
Old Jan 19, 2014 | 06:34 PM
brownbomber77's Avatar
Ya, the 350 headers, especially the driver's side, stick out more because the extra clearance from not having the higher deck height. If you use small block headers on the a big block, the driver's side at least, will hit the steering shaft.
CuttyShark
Aug 16, 2015 04:05 PM
car_designer
Jun 3, 2012 06:03 PM
Wyze
Mar 18, 2012 01:59 PM
barry442
Oct 17, 2009 07:31 AM
