Flowtech
Old Jun 16, 2017 | 09:39 AM
KDW's Avatar
KDW
Flowtech
First I'm looking for something that fits that won't hang low!!!! and not hit stuff
Tried a few
Dick m
Flow
Who has something that will fit
Motor mount are new and correct
Brake lines relocate
455 1972 cutlass
Now the rant!
Hello olds guys have a question about headers from flowtech,
I recently purchased a set of headers from summit racing who's a distributor for flowtech. When I received my headers one tube was bent/smashed/ i.e. Hammered from the factory.
Summit gladly exchange them how every same problem with second set.
I'm curious as why? My old set that was purchased a few years back dose not have this ugly bent/hammer tube and they fit not touching anything.
Has anyone one else had this recent problem. See photo
Old Jun 16, 2017 | 09:46 AM
No photo
Old Jun 16, 2017 | 10:19 AM
KDW's Avatar
KDW
Old Jun 16, 2017 | 10:21 AM
KDW's Avatar
KDW
Old Jun 16, 2017 | 10:23 AM
KDW's Avatar
KDW
Old Jun 16, 2017 | 10:37 AM
KDW's Avatar
KDW
Old Jun 16, 2017 | 10:38 AM
KDW's Avatar
KDW
Old Jun 16, 2017 | 10:40 AM
KDW's Avatar
KDW
First one is new flowtech with bent tube new !
Next 3 Dmr
Last is flow tech! Low hang
Everyone say this stuff fits! Where?
Old Jun 16, 2017 | 01:41 PM
Persuading (dimpling) headers is generally a part of the install with inexpensive headers. Hookers are known to hang low, Hedmans not so much. You can try American Racing Headers or Kooks.
Old Jun 17, 2017 | 01:51 PM
TripDeuces's Avatar
Since ARH was mentioned here are a few shots of my ARH headers on my 66. They fit beautiful except for one tube. It was a little close to the block but I massaged it for a better fit. I'm using a Canton oil pan and the headers are slightly higher than the bottom of the pan. You're going to pay a lot for this type of fitment and because they are stainless.
Old Jun 17, 2017 | 02:35 PM
Tedd Thompson's Avatar
From what I've read it takes a major ding to show up on a dino. If looks appearance are the problem well that is a different matter.... Tedd
Old Jun 17, 2017 | 06:57 PM
KDW's Avatar
KDW
Thanks guys for all the feedback
Tripdeuces thats what I'm looking for, lots of guys claiming they have quality header and never send a pic !
Thanks so much for taking the time and sending pic
I will be ordering mine on Monday !
The only question is you think 1 7/8 or 2 ? my car is mild with stock edelbrook heads .030 over 510 522 lift cam 227 232 duration 780 quick fuel.
Thanks guys
Old Jun 17, 2017 | 07:11 PM
Qwik71442's Avatar
Full-time Taxpayer
Thanks guys
I too have a few sets of ARHeaders both the 1-7/8" and 2" both fit well. For your mild setup I would do the 1-7/8" with the 3" collector. I would also add the 02 bungs in case you should need them down the road. They do not come with collector flanges unless you specify you want them. Here are a few pictures of the 2" installed. The collectors are higher than the oil and transmission pans. You will also need the 9510 powermaster starter with the ARHeaders.
Old Jun 17, 2017 | 08:32 PM
KDW's Avatar
KDW
Qwik71442 look great! So yes I will have O2 bungs and flanges installed. I currently have a msd mini Starter that will work. My exhaust is 2 1/2 all the way to rear bumper. Going change out my h pipe to x also changing out 2 chambers flow to delta 50 mufflers
My 2 chambers bark loud!
Old Jun 18, 2017 | 06:27 AM
wr1970's Avatar
I don't know what a MSD starter is!But the ARH headers were designed for Power Master 9510. If you try anything else you may have a problem. I love my 2inchx3 1/2 ARH headers. My buddy has a set on order right now after checking fitment on my 1970 442. They told him 15 working days.
Old Jun 22, 2017 | 01:33 PM
KDW's Avatar
KDW
Hello just checking in i order my headers from ARH on Tuesday we'll see how this goes. Will keep you updated.
Old Jun 22, 2017 | 01:37 PM
KDW's Avatar
KDW
I have one more question, the headers are stainless, is there a need to ceramic coat them? What are you guys doing?
Old Jun 22, 2017 | 03:31 PM
TripDeuces's Avatar
I'm going to coat mine eventually. Stainless will not stay looking like the pics posted. It will turn blue and a copper reddish like color. It doesn't hurt anything so to each his own.
Old Jun 22, 2017 | 09:25 PM
KDW's Avatar
KDW
TripaDeuces Thank for quick response I'm going to check fit first than send them out. Are you using v bands? If so what kind
Old Jun 23, 2017 | 06:52 AM
TripDeuces's Avatar
I plan to use V band clamps on the collector and maybe some other spots but that is to be determined later. I found some inexpensive clamps through Summit that look pretty sturdy.
https://www.summitracing.com/parts/sum-694350
Old Jul 3, 2017 | 04:43 PM
AK71CutlassS's Avatar
Not hijacking. But I have kooks headers for a 71 Cutlass S. They are bare metal. Should I get coated now. Or will they need to be dented for fitment. ??
Old Jul 3, 2017 | 05:44 PM
KDW's Avatar
KDW
don't know. I've tried a set of used Dick miller headers would not fit have to put many dents to fit. i sent a pic of the headers to Dick miller he just said there are a couple of variations of the header could not tell me much!
You up would think if there making them would have done ideal of what they are. I guess could bought pair from him, didn't seem like he wanted to help so I went to ARH still want on them to ship.
You up will have to try those kooks to see if they fit. You have any picks.
Old Jul 3, 2017 | 08:33 PM
Qwik71442's Avatar
Full-time Taxpayer
You probably need to test fit them first to know for sure if they will need to be clearanced or not. From what I've experienced the old Kooks are nearly identical to the ARHeaders so I would bet they fit perfectly without any modifications. Here is an old set of Kooks I had ARHeaders replace the standard collectors with the merge collectors.
Old Jul 3, 2017 | 08:41 PM
Yeah I'm hoping they fit without mods. I want to get them coated before hand. I'm going to. Be running my engine on a test stand way before it goes in the car. But I'd rather not dent them after coated. Just wanna see if anyone runs kooks and knows this
Old Jul 9, 2017 | 05:57 PM
Kooks
Kooks
Old Jul 19, 2017 | 10:03 PM
KDW's Avatar
KDW
Starter
Hello so I got headers they rely nice. Also got a power master start is there a trick for installation? Dose stater go first that header?
I tried to install header with two bolts loosely looks like starter is to long. Starter is powermaster 9510
Old Jul 19, 2017 | 10:30 PM
Qwik71442's Avatar
Full-time Taxpayer
They have to go in at the same time. Header needs to be in position completely loose as you work the starter into position and bolt the starter down.
Old Jul 20, 2017 | 02:41 PM
KDW's Avatar
KDW
headers ARH
ok I'm missing something they not going in at all! My start is the same as yours. Is it possible you chang the clock position on the starter yours looks different? Your looks like it's at the bottom?
Old Jul 21, 2017 | 09:27 AM
Can you post a pic of whats interfering?
Old Jul 21, 2017 | 09:39 AM
KDW's Avatar
KDW
ArH
So I won't have a pic till Monday. The header is installed with starter the only way it would go in without interference was to reposition starter clock! Starter motor was hitting second tube! Don't know if this will effect starter rotation....don't think it will any comments or has any else had this problem
kevin.horton
May 30, 2012 07:12 AM
L69
Jan 9, 2012 05:59 PM
Mark71
Jun 27, 2011 09:43 PM
defiant1
Oct 21, 2010 02:41 AM
