Flip stock pistons around. Piston offset.
Stock 455 re-ring. Flip stock pistons around. Piston offset.
![](https://cimg2.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1504/b48527ab_ea91_4026_a30a_35acd2727f78_38768f1d2e38627adbc60bae5a3b71958e10dd8c.jpeg)
I have a stock high compression 455 that I want to re-ring. Is it advisable to turn the pistons around to use the built-in pin offset to make more power?
How much do you want to listen to the knocking that is reduced by offsetting the pin?
The whole reason to offset the pin is to cut down the piston slap. You turn it backwards, the knocking is even worse. Especially on a worn cylinder bore. But what do I know? Maybe you have a really loud radio.
There there's the issue of having to press the pistons off the rods. Be lucky if you don't score a piston pin, or break a piston in the process. OR you could take the piston and rod and move it to another hole so the piston offset ends up bass-ackwards, but you have to make sure the bearing offset stays correct.
Far as I'm concerned, it's nothing but heartache.
My rods that are in my 455 now are “backwards.” The pistons are not
Hell, no.
How are the crank fillets not riding on the bearing edges? I'm gonna have to dig out the 425 rods from the barn and take a look at them. My 455 photos are inconclusive.
If you really want to do it all you would have to do is swap the piston and rod assemblies from one side of the engine to the other. You dont need to press them off and back on. Personally I dont think you will gain anything on a stock engine.
Vin if you want better performance then replace the pistons with a set of Wisecos in std. They make em.
This is an old thread, but I was wondering about a mild street stroker build for a 307 Olds. If you use the 3.51" offset crankshaft, 6.250" LS Rods and LS pistons that are 3.799" plus .030" we have an engine that displaces 323ci and if we add up the numbers we have 9.33" that is very close to the deck height.
Your thoughts?
Your thoughts?
I should add that that compression height of the pistons is 1.325"
Here is the calculation
3.510"/2 = 1.75"
1.75 (stroke) + 6.250" rod length + 1.325 compression height = 9.33"
Is the deck height on the 307 the same as a 350?
If so what would the compression be on a motor with 5A heads?
3.510"/2 = 1.75"
Are there valve reliefs on those "LS" pistons, and are they in the right place for the Olds valve positions?
Deck height of all Olds small blocks is the same within typical production variations.
Without more info on the pistons, and head gasket thickness, there's no way to calculate compression. Might be worth actually measuring the chambers on the heads, too,
3.510/2 is 1.755. Just do 3.500 with the 6.250 rod and 1.325 comp distance piston. That’ll give you approx 9.325 in total distance. That should give you right about a zero deck.
