Exhaust Manifolds
Old Apr 26, 2014 | 09:50 PM
Gary's 2 442-S's Avatar
Gary
Exhaust Manifolds
Does anyone know which manifolds should be on a 68 442 with 455? What is on there now is an "X" manifold on the left side and a "Y"manifold on the right. I do believe the Y manifold is not the correct one. It is badly cracked and I am going to have to replace it. I think that "W" manifold should be correct. In the beginning process of the restoration of the 68 convertible.
Gary
Old Apr 26, 2014 | 10:18 PM
Gary
Well after doing further research I found that the Y manifold is correct for the 68 afterall. It was specifically for 68 only. I should be able to use the W manifold.
Old Apr 27, 2014 | 05:30 AM
Macadoo's Avatar
Just from months of reading here on CO, I do believe you should have the X and Y manifolds. But I can't help with the W manifold, sorry.
Good luck with the resto
Old Apr 27, 2014 | 04:19 PM
Gary
X/Y are correct for 1968 only. If you are going to change, use the W/Z manifolds as a pair. The X/Y manifolds are open log designs. The W/Z are individual runner and will provide a small flow improvement.
Old Apr 27, 2014 | 04:35 PM
Gary
Thanks Joe, I was leaning that way with the pair.
bulky
Aug 28, 2006 11:59 AM
bulky
Jul 20, 2006 12:56 PM
linas9
Feb 23, 2006 01:10 PM
EdsDelta
Jul 22, 2004 11:46 AM
copper128
Mar 21, 2004 09:43 PM
