Engine Pro Camshaft
Old Apr 24, 2012 | 08:19 AM
pcard's Avatar
70 Cutlass SX
Engine Pro Camshaft
Hey - my 455 (1970 SX) was just finished and the builder put in an Engine Pro MC2010, Stage 3 Cam:
Duration at .05: 214/224
Duration: 280/290
Lift: .472/.496
Lobe Sep: 107/117
Anyway, I had wanted a fairly stock cam with a bit of a performance upgrade, but appropriate for street use. This cam seems a bit radical for me, but was hoping to get your comments on the specs and also if anyone has had any experience with Engine Pro products.
I have a TH400 with 3.08 rear end, 215-75 R14 tires, dual stock exhaust system, stock intake, stock 4B quadrajet, stock ignition, power brakes. The rest of the engine rebuild was fairly stock with new Keith Black pistons KB277 30 over.
Here is a link to the Engine Pro site:
http://www.enginepro.com/oldsmobile.html
Thanks, Peter
Last edited by pcard; Apr 26, 2012 at 05:13 AM. Reason: format and additional information
Old Apr 24, 2012 | 08:44 AM
cutlassefi's Avatar
Those are all generic grinds, you should be fine but they are a bit lazy.
I hope he didn't charge you more than about $80.00 for that cam, they're available everywhere.
Old Apr 25, 2012 | 06:25 PM
pcard's Avatar
70 Cutlass SX
Not sure I understand what you meant by "but they are lazy?". Could you elaborate?
Thanks.
He charged me a bit more than $80, but he has to make money too.
Old Apr 26, 2012 | 05:00 AM
507OLDS's Avatar
It's more of a dated,obsolete grind.With today's knowledge & technology,there are a lot better grinds out there.
Old Apr 26, 2012 | 05:03 AM
pcard's Avatar
70 Cutlass SX
Thanks Brian. Could any one offer a specific suggestion, considering I did not want to be too radical, with some good low end torque.
The engine is still out of the car, and if there is an opportunity to change the cam it is now.
Old Apr 26, 2012 | 06:45 PM
pcard's Avatar
70 Cutlass SX
Joe - thanks for the info.
After reading a bunch of stuff I now know what a "lazy" cam means.
All in all I decided I am going to keep the cam that is in there. Since it will be street and highway ride I do not not need anything too big, and am looking for quiet effeciency.
Thanks to everyone for their time and thoughts.
Peter
Old Apr 26, 2012 | 06:53 PM
cutlassefi's Avatar
Originally Posted by joesw31
Looking at your application and your intended use. The cam selected would be appropiate. However, looking at the web page you provided, it appears that the base circle of the camshaft is smaller and may require an adjustable valve train. The camshaft being supplied is a generic camshaft. The term generic meaning the camshft can be purchased under different brand names. However, it is still the same camshaft.
In the event you decide to change your camshaft. You can try a compcams 42-306-4. The cam specs out at .222/.226 with .494 lift on a 110 LCA
Just an FYI, that's incorrect. You're describing duration, there is no decimel point in that. The editors on HP TV make the same mistake all the time. And LCA is centerline, that's adjustable, normally it's stated as LSA, that's ground into the cam.
Size has nothing to do with whether or not it's lazy. You can have a small cam that's lazy and big one that's not.
Old Apr 26, 2012 | 11:11 PM
ah64pilot's Avatar
I once got a cam that was 2.26 / 23.00 @5.00 4.96 / 5.12 lift on a .110 LCA, it was a great mix of street and strip and wasn't too loud. But it was a bit lazy as well...it wouldn't get in the engine when I told it to. I had to pick it up and put it in myself.
Old Apr 27, 2012 | 04:25 AM
firefrost gold's Avatar
Then y0u have to spank it.
Old Apr 27, 2012 | 06:32 AM
jslabotsky's Avatar
Telecom Guru
What I want to know is where I can get one of these cams for $80.00 retail. The cheapest I've found any of the "generics" is about $100.
Old Apr 27, 2012 | 07:01 AM
pcard's Avatar
70 Cutlass SX
If it is lazy then send it to the Army (or Air Force ).
But seriously:
- so does "lazy" mean that it is a bit slow of the mark?
- does "big" mean long duration and high lift?
I paid $116 for my cam, but that was through the installer, who ordered it and had it shipped. I would imagine his cost would be about $85.
Old Apr 28, 2012 | 08:43 AM
jslabotsky's Avatar
Telecom Guru
But seriously:
When Mark says it's "lazy", he means the ramps are less steep/aggressive. It takes more degrees of rotation to get to max lift. Consequently, the valve doesn't spend as much time at higher lift where there is more flow.
Yes, big generally means more duration and lift.
By way of comparison, the Lunati 00083 (which is supposedly a "generic" grind you can get from Edelbrock and others) has these specs:
Advertised duration: 290 int/300 exh
Duration @ .050": 224/234
Valve Lift with 1.6:1 rocker: .496"/.520"
Lobe separation: 112 deg
The Engle/Mondello JM20-22 has these specs:
Advertised duration: 266 int/274 exh
Duration @ .050": 226/230
Valve lift with 1.6:1 rocker: .496"/.512"
Lobe separation: 110 deg
The .050" duration and total lift of both cams is pretty close, but there's a pretty big difference in advertised duration. So the Engle is going from zero to full lift more quickly than the Lunati. So even though both have similar .050" duration, the Engle will keep the valve open farther for a longer portion of that duration than the Lunati. (More "area under the curve".)
The Engle also has less overlap (although the Lunati has 2 deg more lobe separation to offset that somewhat). With less overlap, the Engle will hold more cylinder pressure, which may be desirable if your compression is on the low side.
Old Apr 28, 2012 | 06:39 PM
pcard's Avatar
70 Cutlass SX
Thanks for the short lesson. This is very interesting; I am going to find a good primer on cam design.
Old Apr 29, 2012 | 04:56 AM
cutlassefi's Avatar
One footnote to that J is that the Engle's advertised specs are taken at .008 tappet lift, the Lunati's at .004. That will make the Engles' seem even faster than it really is when compared to the generic ones.
It is a fast ramp cam and they tend to be noisy but ramp profiles different in the way they accelerate the lifter throughout the lifting phase.
More area "under the curve" is better in most cases but not always.
Take a syringe and hold your finger over the end covering the hole only partially, then retract the plunger quickly. It's hard to pull open isn't it. That may happen if you have ports that don't flow that well. Now do it more slowly. That's why on stock iron headed applications I don't normally recommend fast ramp profiles. You may not have enough off the seat time on a fast ramp cam to better utilize your port characteristics.
If the fast ramp stuff was really for everything, don't you think the cam companies could save money by reducing thier inventory to only those grinds, I do. But on the flipside there are better grinds than the generic stuff too.
Hope this helps.
Old Apr 29, 2012 | 05:38 AM
How can you tell by him posting the lift and duration. If cam A is the same numbers as cam B how do you know cam a is a fast ramp and cam B is a lazy ramp ? I understand the
speed or off seat time part but how do you know this cam is said lazy or outdated ?
Old Apr 29, 2012 | 03:00 PM
cutlassefi's Avatar
Let's take 2 hypothetical cams with the same at .050 and both have their advertised duration taken at .006 of tappet lift.
1) has 285/300 advertised, with 228/235 at .050
2) has 274/286 advertised with the same 228/235 .050.
Cam #1 is slower because it has a total of 285/300 off the seat time in order to achieve the same at .050 numbers as Cam #2.
By the same token take the W-31 cam, 308/308, 232/232 at .050. This would seem way slower than Cam #1 but advertised figures back then were taken at .000 tappet lift. So even though it is slower than both #1 and #2 it's maybe not as much as it seems.
But something else to consider, how long does the fast ramp cam stay at max lift? Does it just kiss it then head back down or does it stay there as long as the slower ramped cam might? That will depend on lobe profile and the printed specs very seldom ever do a good job of describing that aspect.
Another potential issue with the fast ramp stuff can be described this way, would it be easier to climb a mountain 400' high if the base was 150' wide or if it was 200' wide? Obviously the latter is true, the faster the ramp the harder it is on parts, period.
Hope this helps.
Old Apr 29, 2012 | 03:55 PM
coppercutlass's Avatar
Chevy budget Olds powered
I thought slower ramp speeds helped air flow in stock heads. That's what I have been told.
Old Apr 29, 2012 | 05:20 PM
cutlassefi's Avatar
They can by helping port velocity.
Old Apr 29, 2012 | 06:12 PM
Cutlassefi Im not busting your chops here. But why would someone want to stay away from a "lazy" cam . i mean we are dealing with 40 plus year old machines here. Assuming there is good compression and the converter is right. What would make these old generic cams less desireable. I have the lunati 00083 on a shelf and im currently running the comp cams 280h . Would the 00083 be better or im better off with what i have. Im currently working on a new shortblock and id like to pick a a cam that would improve my performance but if the one i have now will work i have it already.
Old Apr 29, 2012 | 06:22 PM
costpenn's Avatar
As an aside here, if you or anyone is wanting to "go ancient" and are wanting a W-31 camshaft (402194), let me know. I've got about 15 left that I got from the OE supplier to Olds back in the day that he was about to scrap!
Old Apr 29, 2012 | 06:41 PM
jslabotsky's Avatar
Telecom Guru
I don't think there is anything wrong with a so-called lazy cam. It just depends on your application. And I seem to recall that Bill Trovato says a somewhat "lazy" exhaust lobe can help exhaust flow by keeping the velocity up.
Part of the deal with most of the the so-called generic grinds is that they are meant to work with a stock valvetrain without causing accelerated wear.
joepenoso
Jan 31, 2013 09:50 PM
olds67
Feb 14, 2010 01:04 AM
442 Guatemala
Jul 24, 2007 11:51 PM
TECH9TWISTA
Jun 25, 2007 12:05 PM
shaks 442 clone
May 31, 2007 08:42 AM
