Engine id
Old Dec 12, 2014 | 01:57 PM
jminor1961's Avatar
Engine id
Hello
I have a motor that is a early 60s I needed to find out what
year is if anyone knows # on the head is G 530721 I would
appreciate any help from anyone
Thank you
Old Dec 12, 2014 | 09:24 PM
Octania's Avatar
Originally Posted by jminor1961
Hello
Thank you
That number is not familiar to me
Interweb search returns only this thread
Perhaps you read it wrong.
Pix?
At least a verbal description of the G 530721- where it is, what size is it, etc.
Olds "G" heads are embossed with cast in # 409100, not even close to what you cited.
Old Dec 13, 2014 | 07:19 AM
Hello
Thank you
HOW "early sixties"? Is this a 394? A 215? A 330? Is this number stamped on the end of the head? Can you post a photo of the engine?
Old Dec 13, 2014 | 07:23 AM
59-59-59's Avatar
I think that the G in the stamping is a '62 394. Is there a large casting number of 18, 20, or 23 on the cylinder head??
Old Dec 13, 2014 | 12:36 PM
jminor1961's Avatar
The number are stamp on the [passenger] right side in the center of the block just below the valve cover. On my 61 starfire its on the left side of the motor in the same place. The number are correct G 530721 at the end of the block there is number 23 The numbers to me should be on the [driver side] left side.The prefix G the same prefix as my starfire jim
805cut
May 3, 2012 08:11 PM
Olds luvr
Mar 17, 2010 06:57 PM
njot33
Sep 25, 2009 09:07 AM
cts-v
Jan 10, 2009 06:20 PM
pinky
Oct 1, 2007 11:24 AM
