Engine finally gave up (Rebuild)
Old September 23rd, 2011 | 09:46 PM
  #41
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
Originally Posted by BosMobile
Great looking project!Does your car have a A/C box ?I'm wondering if those valve covers would clear on my 72.That duel carb setup looks very cool too,Thanks,BO
I don't have A/C, hard to say if they'll clear. They're roughly 1 1/4" taller than stock, correction M/T covers.
Last edited by 67Olds442X2; September 23rd, 2011 at 10:03 PM. Reason: Added correction
Old September 23rd, 2011 | 09:51 PM
  #42
ah64pilot's Avatar
Hey Bos, I am currently in the process of clearancing my A/C box for tall valve covers. I already laid the fiberglass and bondo'd it today. I will start sanding tomorrow. I'll take a few pics, if nothing else, you could do the same to yours for 2 days work and a little glass.
Old September 23rd, 2011 | 10:37 PM
  #43
BosMobile's Avatar
Thumbs up
Thanks,are you using the same valve covers?I'd seen those in the past ,but i think they were a lot more expensive then,I dont have A/C anymore but i still have the air box to retain the heater for now.Havent switched to the A/C delete box or cover yet.Probably fabricate somthing there .So doing what you are will work for me.[hope "santas"whatching!]Later,BO
Old September 24th, 2011 | 04:34 AM
  #44
CutlassLegend's Avatar
Dan the motor looks great and sounds awesome. I may have to take a ride down your way so we can have a few espressos and take that beast for a ride. My project is going at a wonderful snail's pace.
Old September 24th, 2011 | 11:00 AM
  #45
citcapp's Avatar
Originally Posted by 67Olds442X2
They're 4" tall from bottom of flange to the top. Outside measurement. My M/T's were 2 3/4". This is the Summit page: http://www.summitracing.com/parts/NAL-22525295/
Thanks for the info. These will work great for me and the price is right as well
Old September 24th, 2011 | 05:22 PM
  #46
Navy P-3 FE (Ret.)
Well there's a little issue with those nice tall GMPP covers. If you use the rocket emblem area for your breather hole, there is a rocker directly below. I had installed my baffled grommet's from Moroso which are 1 1/2" long and had oil spray out the breathers. I installed my PCV valve and if I use that setup i'll just end up sucking oil out. Need to find a different baffled grommet.
You got to be careful what you use because the rocker arm is directly below. I guess it's best not to use the emblem area. The "O" in Oldsmobile maybe.
I"m going to try the plain grommet which is shorter since the covers sit higher, it might be enough so as not to pass oil. I'm going to get a breather with built in PCV.
Old September 24th, 2011 | 08:08 PM
  #47
ah64pilot's Avatar
Bos, I finished the evaporator box...I'm not trying to hijack Dan's thread here so check it out on my major builds and projects thread New Engine, New Paint, New Interior...HERO camera Documented
Old September 28th, 2011 | 09:34 PM
  #48
Navy P-3 FE (Ret.)
The next step is installing the new radiator. I'll stop here because this thread probably belongs in projects.
Old September 29th, 2011 | 11:13 PM
  #49
64Rocket's Avatar
You need to build a baffle for the PCV set up. I use a piece of aluminum and a self tap screws with lock tight and some silicone over the screws.
Gene
Old September 30th, 2011 | 04:22 AM
  #50
Navy P-3 FE (Ret.)
Gene
I'll try to make something. Today I had a breather blow out, what a mess that made under the hood. It wasn't in all the way.
Old November 18th, 2011 | 04:40 PM
  #51
Navy P-3 FE (Ret.)
Finally got some braided line to replace the rubber hose. Also replaced the transmission lines with braided line. Engine still running strong. Oil pressure stays above 30 psi and temp stays below 195 sitting in traffic, 165 cruising around.
Old December 15th, 2011 | 05:32 PM
  #52
ROBZ442's Avatar
Glad to see you got things sorted out. Looks great. Did you do anything different this time around? Just curious, I'm getting ready to go through mine again for the third time. I could use all the help I can get.
Old December 15th, 2011 | 06:04 PM
  #53
Navy P-3 FE (Ret.)
I had to use a different crank and I had that turned. Resized the rod that spun the bearing and had three wrist pins fixed, the pistons didn't move freely. I'm using a different set of rockers and that's about it. Can't say I really did anything different in the rebuild, I did install the rear main seal the correct way the second time.
Better yet if you want my cell is 301-481-4940. Feel free to call (EST), I have a hard time typing besides trying to put thoughts down. I'm no expert but I could explain what I did.
Old December 16th, 2011 | 12:45 PM
  #54
ROBZ442's Avatar
That works for me. I am busy tonight but will give you a call mid day tomorrow.
Rob
coppercutlass
April 26th, 2014 04:29 PM
64 Oldsmobile
December 23rd, 2013 11:12 PM
crazy'boutOlds
June 2nd, 2013 12:43 PM
67Olds442X2
August 21st, 2011 08:22 AM
olds307owner
May 17th, 2007 08:48 PM
