Electric Fan
Old Aug 14, 2012 | 11:12 AM
75cutty455's Avatar
Electric Fan
I have finished my build on my 68 455 and decided to go with an electric fan out of a 1995 Lincoln Mark VIII. It is a two speed fan so I wired it up to the high speed wire and connected it to a manual switch. I also put a 100 AMP High Output alternator on there to accomidate the constant 30 amps I hear it pulls.
Ive been riding for a few days and it is great. I waited till the temp gets to about 230 degrees (numerous times)and turned the fan on. It cools to approx 190 in 1min 34sec. I know right! I timed it. This is my first time doing this so I dont know if that is good at all or even if its as great as I am making it sound.
With the fan on the temp never goes above 195.
Just thought I would share this
Old Aug 14, 2012 | 12:20 PM
RetroRanger's Avatar
72 Olds CS
195 sounds reasonable.
230 sounds kinda hot I would turn it on at 200 and leave it on if it 'runs' at 195. or bettter yet hook it to a thermostat switch to turn on by itself...if its just threw a switch you should use a relay w it
BTW I dont think it draws 30 amps thats alotta current...is what I was going to write but a quick search shows indeed there are many fans availible that do draw that much current
Old Aug 14, 2012 | 12:24 PM
ah64pilot's Avatar
Definitely run it through a relay. But you are better off using a temperature switch, and then you don't have to think about it. I set one up the way you did years ago and I burned up the switch while out on a cruise...no fans, and running hot...not a good feeling.
Old Aug 14, 2012 | 01:29 PM
bccan's Avatar
Not exact but close.
Old Aug 15, 2012 | 04:25 AM
75cutty455's Avatar
Wow, thats pretty good info. Thanks
Old Aug 19, 2012 | 08:39 AM
therobski's Avatar
Yes indeed 230 way too hot for the 455. These old bad boys run much better on the cool side. I have experienced on the high performance side of things you can get a little more timing out of cooler running 455. Either way sounds like you will fix it soon.
convertible 63
May 9, 2018 06:10 AM
agtw31
Jun 23, 2009 01:39 PM
shaks 442 clone
May 3, 2007 12:36 PM
Redog
Dec 29, 2006 12:38 PM
Redog
Nov 9, 2006 05:41 AM
