Edelerock Performer
Old Dec 24, 2011 | 01:03 AM
Young Man's Avatar
Edelerock Performer
I'm wonder what the differenc in stock manifold vs Edelbrock Performer are. The engine is stock -72 and it runs real good
ps. Merry Christmas to all
Old Dec 24, 2011 | 06:20 AM
firefrost gold's Avatar
http://www.bing.com/images/search?q=...=0&FORM=IDFRIR
Big Block performer vs stock
It is 40lbs lighter than the stock intake much easier to set back on the intake for one person. The perfromer is a little taller and has a large plenum the ports are split at the plenum vs the farther down the runners like on a stock intake so air keeps moving all the way to combustion chamber vs the stock intake T-ing and making the air decide to go left bank or right. Many old school olds guys say the performer is worth the time and money and work
for a street car and they work with any carb you already have .
Small block not as dramatic of a change still weight's less a and ports split at plenum but not as tall of plenum
Old Dec 24, 2011 | 07:44 AM
70olds455's Avatar
The edelbrock performer is a lot lighter and you will make more horsepower with it.
Old Dec 24, 2011 | 09:33 AM
cutlassefi's Avatar
X2
Old Dec 24, 2011 | 10:05 AM
Don L/442's Avatar
I have a manual choke set up so not having the heat riser works great and a 3" x 14" air cleaner fit no issues. '69 442 w/455
Old Dec 29, 2011 | 11:00 PM
rubeng442's Avatar
The weight savings alone are probably worth the switch.
Old Dec 30, 2011 | 06:57 AM
72 w29 all green's Avatar
Just another opinion here. Since "it runs real good" as stock, i'd just leave it as is unless you were going to make other performance upgrades to go with the Edelbrock intake. Also, 40lbs. weight savings would be nice but you wouldn't notice it on its own.
Old Dec 30, 2011 | 07:11 AM
all green you now how guys are we cant leave anything alone add in the young part and that drive is even greater! But YOU ARE RIGHT unless he has a two barrel set up or is going to be pulling to do a gasket fix he might be better to clean his up real goood mask it off an paint and primp what he has. A nice clean stock engine bay is very cool too. Many of us wish they still had the stock intake for their car on here. Im one of the first in that line, it will coast me three to four time's what a edelbrock intake is IF I ever find one.
Old Dec 30, 2011 | 02:05 PM
MX442's Avatar
OK, so this is for big blocks, I'm sure SB is similar. Height and weight. On one of these forums I posted the weights, but don't remember where. They were NOT 40 lbs lighter! If I recall, the weight difference was less than 20 lbs..
jasoneswan
Jul 2, 2008 02:59 PM
jrblanke
Jan 10, 2008 05:19 PM
blue72regency
Oct 27, 2007 09:47 PM
JoshF85
Feb 28, 2005 11:58 AM
