edelbrock 750 cfm
edelbrock 750 cfm
So last season I installed a new edelbrock 750 cfm carb and I was just doing some reading on what jets it has stock for the secondary...0.107
I have a tuning kit for this carb and was wondering what would be the difference if I went up 2 stages to 0.113??? would it give the engine more power,,,,more fuel...more power???
comp cam 262h
sealed power pistons .030 over
stock G heads
hei ignition
comp cam 262h
stock G heads
hei ignition
with a mild 455 it should be pretty good on seconday jets. I would paly with the power piston springs and rods. the stock spring is too low vacume for a mild set up . they are ok for a street carb . problem with big cube engines the secondarys open too fast and make a lean stumble when nailing it.
vette442
September 6th, 2013 04:57 AM
