Distributor curving for cam
Old Oct 22, 2013 | 02:33 PM
jensenracing77's Avatar
My engine guy just called and ask me several questions about my build. One thing he mentioned was that if I am going to use the stock distributor I need to have it machined for 20 degrees initial advance to work good with my cam. I have never been any good at this area of tuning. What say the pros here.
My cam specs are..
289/299 advertised duration
231/237@50
Lift .563/.560
On a 112 lobe sep. The cam card will reflect an advance of 3 degrees.
full roller
stock F heads
10.0:1 compression
stock intake and exhaust manifolds
Will also have power brakes and A/C.
Old Oct 22, 2013 | 03:21 PM
What distributor are you using?
Old Oct 22, 2013 | 04:10 PM
I was going to use a stock 70 442 automatic distributor but if it has to be modified I will use a standard 455 distributor.
I just talked to another member and think I have a better understanding for what I need. I will have to talk to the engine guy again because I think I may have some terminology wrong.
Old Oct 22, 2013 | 04:31 PM
Here's a simple view, I know it's for a chevy but the principle applies to all V8's.
http://www.chevyhiperformance.com/howto/46178/
And this has a bit more info:
http://www.gofastforless.com/ignition/advance.htm
scrappie
Feb 11, 2014 07:03 AM
chris83
Aug 18, 2012 01:47 PM
coppercutlass
Nov 21, 2011 10:06 AM
70Cutlass_408
May 23, 2011 01:34 PM
scott_442
Oct 8, 2008 09:41 AM
