Deciphering 455 Code
Old Mar 27, 2022 | 08:01 AM
gritten's Avatar
I bought a 68 455 years ago as a core and am finally starting the rebuild process. The stamped code is 38X166763. I was told by the seller the engine was pulled from a Delmont, but I can't find any reference online to an X build location. Is this perhaps a service replacement block? I look forward to your feedback. Thanks.
Old Mar 27, 2022 | 09:54 AM
hurst68olds's Avatar
"X" is Kansas City, KS & built full size (non-Toronado) Oldsmobiles (71,481 of them)
Old Mar 27, 2022 | 10:00 AM
gritten's Avatar
Great...thanks!
Old Mar 27, 2022 | 10:10 AM
if "they" were accurate - the VIN would've been 3xxxx8X166763
there were 4 models in the Delmont 88 line-up (replaces the "xxxx" in the above VIN):
5439 - Delmont 88 Holiday Sedan
5467 - Delmont 88 Convertible
5469 - Delmont 88 Town Sedan
5487 - Delmont 88 Holiday Coupe
Old Mar 27, 2022 | 10:39 AM
Which is why you should not rely on online sources for accurate information. Note that pretty much anything you find about Oldsmobiles online will only apply to 1968-72 A-body cars, and probably 80% of it will be incorrect.
Technically "X" was the Fairfax, KS assembly plant. There was also the Leeds plant (VIN code "K") located in Kansas City, MO.
Tfitz
Feb 9, 2016 03:39 PM
cdoering
Jul 21, 2014 05:36 PM
Allan R
Oct 7, 2012 02:02 PM
bobb
Oct 8, 2010 03:40 PM
455nova
Feb 9, 2007 05:28 PM
