is this a cross drilled 400bb crank?
Old Apr 26, 2013 | 05:54 PM
oldsmosteel's Avatar
hi all, bought this 400 G block about a month ago.. still on the fence about rebuilding or reselling. if this is a cross drilled crank i might just keep it as i want to run a manual trans. is this what a cross drilled crank looks like?
thanks
Marty
Old Apr 26, 2013 | 06:06 PM
I thought I was gonna see a picture of the oil feed holes in the main journals.
Are you perhaps asking if the crank is drilled for a pilot bushing?
Old Apr 26, 2013 | 06:09 PM
yes!
Old Apr 26, 2013 | 08:37 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
looks like automatic only.
Old Apr 27, 2013 | 06:29 PM
Octania's Avatar
I'll say AT originally but looks lilke a 3-step drill, easy convert to MT use with the alternate bearing.
Old Apr 28, 2013 | 12:39 PM
thanks. i'll look into that. i'm getting a smokin deal on a running '71 delta 88... 4bbl carb running 455 & turbo 400 trans. from the negs i've read about the 400 g blocks i might just let it go & keep the AT & 455 instead. pretty sure the 400G was an old Toro engine as it has the notch in the oil pan. so i'm thinking shouldn't be too hard to find a buyer for it.
Marty
Napoleon1991
Jul 20, 2020 11:12 AM
starfire
Brakes/Hydraulic Systems
May 26, 2015 09:30 AM
halfmoontrail
May 31, 2013 05:41 AM
krooser
Feb 15, 2013 04:32 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
