can you get a lifter out without pulling heads?
Old May 8, 2009 | 04:15 PM
Flye's Avatar
67 400
If I go that far, I probably should pull heads and have them redone, but just for my knowledge base.....
Can you pull intake, and pull push rods and get a lifter out, or does the head have to come off?
Just trying to figure out options.
and yes, I realize many will say "just pull heads and do valves if you're that far....".
Thanks,
Old May 8, 2009 | 05:07 PM
don71's Avatar
same but different
The head doesn't have to come off per say, they can pulled out from the valley.
Beware....there can be a build up of varnish/gum deposits that will make them very stubburn and tough to pull out. If that happens, you have to knock them into the engine. You'll be pulling the oil pan off to get them out, not the heads.
edit...in order to knock the lifters in the engine, the cam has to removed.
Old May 8, 2009 | 06:40 PM
Bass ackwards is possible but not advisable.
Pull the heads.
Old May 8, 2009 | 06:55 PM
jensenracing77's Avatar
you don't need to pull the heads. if you have a stuck lifter in the bore you can pull them out with an internal barring puller for small barrings. you will ruin the lifter doing this.
Old May 8, 2009 | 07:34 PM
OR...
You could just get the right tool for the job and not ruin anything.
http://www.amazon.com/gp/product/B00...&redirect=true
Old May 9, 2009 | 04:17 AM
scrappie's Avatar
That looks like the tool to use. I don't understand why the head should come off to get a lifter out? After the intake is removed you can get to the lifter with that tool Joe suggested or not. How would the head being removed give you more access?
Old May 9, 2009 | 05:13 AM
OR...
that is the same thing as my little internal barring puller. i just figured it would scuff the lifter.
Old May 9, 2009 | 07:07 PM
It's not the same as a BEARING puller. The lifter puller has small teeth that are designed to fit into the snap ring groove on the lifter so there is no damage. The black cylinder acts like a slide hammer to knock the lifter out. If that doesn't work, the nut on the upper part can be threaded down against the head (the puller rod fits through the pushrod hole) to pull the lifter out.
Old May 10, 2009 | 08:13 AM
Warhead's Avatar
Riddle me this, Batman...
How many miles on this engine, and why do you want to pull them?
Yes you can do this.
If you want to do a cam swap on a high mileage engine, I DO recommend pulling the heads (but you know that already).
Jim
MDchanic
31
Aug 12, 2012 04:24 AM
getitmann
Jul 12, 2012 06:58 PM
ChefDeadpool
37
May 23, 2012 08:32 PM
Aceshigh
Sep 29, 2010 10:31 PM
krissiibabii
Aug 18, 2010 05:35 PM
