Camshaft Suggestions
Old Feb 24, 2026 | 01:51 PM
DanM's Avatar
Awesome User
Looking for suggestions for a cam for this setup.. I want to be sure I still have vacuum for power brakes and can idle at a red light comfortably especially for A/C.
Olds 455 'F' block - bored out to 4.185
Pistons: DSS Racing FX Series forged flat top, 4.185" bore, -12cc, 1.75" CH
Rods: Scat H-beam 4340 forged, 6.735" length, ARP 8740 bolts
Cylinder Heads: Edelbrock 61025 Performer
Lifters: COMP Cams Evolution Roller Lifters 85701-16
Crankshaft: Original, undersized journals, polished and balanced
Rockers: Harland Sharp roller tip, 1.6 ratio - S5016
Intake: Edelbrock Performer
Pushrods: 3/8"
Oil Pan: 7 Qt Milodon
Oil Pump: Melling HV Pump
Timing Set: Comp Cams 3113 - from 2004
Carb: Holley Street Avenger 770 CFM (may have to upgrade to more CFM but using this for now)
Distributor: MSD Pro-Billet Ready-to-Run with older MSD 6AL box
Headers: Hooker Super Competition
Exhaust: Pypes 2.5" X-Pipe
Torque Converter: Coan Engineering 11" Pro Street, 2800-3200 estimated stall
Transmission: TH400 with Trick Kit
Rear End: 3.42 Gears with Positraction
Edit: +12cc on pistons. Compressions will be around 10.6-10.7 with a .040" head gasket
Old Feb 24, 2026 | 06:05 PM
Maybe use a font that is readable?
Old Feb 24, 2026 | 06:53 PM
v8al's Avatar
Registered Olds Owner
Lifters: COMP Cams Evolution 85701-16
Pushrods: 3/8"
Old Feb 25, 2026 | 02:38 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
Its just fine using the dartk theme lol
Old Feb 25, 2026 | 04:05 AM
BillK's Avatar
What is the planned use of the car ?
Old Feb 25, 2026 | 06:08 AM
DanM's Avatar
Awesome User
Mostly street and cruising, which is why brakes and a/c are important
Old Feb 25, 2026 | 07:03 AM
BillK's Avatar
That's a tough one. If I am doing the math right you are at almost 11.75 to 1 compression ?? I think its going to be hard to get a cam with the characteristics you want and still run worth a darn. I would have to call a couple of the cam manufacturers and ask their advice. Almost certainly going to have to be a custom grind.
How about an electric vacuum pump for the brakes ?
I think the performer intake might be a killer too.
Old Feb 25, 2026 | 07:40 AM
Duh's Avatar
Duh
Your going to want to stay below the high 230@50 and have a min of 110 LSA. Your 770 will be more than enough. Your going to have to run 92 or better octane and its best to have a non aggressive timing curve.
Old Feb 25, 2026 | 08:20 AM
DanM's Avatar
Awesome User
Should be +12cc on the pistons as it has a dish/valve reliefs. Compression will be around 10.6 to 10.7. Head gasket adds .040"
Old Feb 25, 2026 | 08:26 AM
cutlassefi's Avatar
Roller or flat?
Old Feb 25, 2026 | 08:28 AM
OLDSter Ralph's Avatar
How deep in the hole do the pistons sit ? What are the head CC's ?
Old Feb 25, 2026 | 10:11 AM
DanM's Avatar
Awesome User
Roller Rockers/Lifters
Block has been zero decked, heads are 77ccs
Old Feb 25, 2026 | 10:48 AM
cutlassefi's Avatar
So you KNOW it’s zero decked or they told you it was?
Old Feb 25, 2026 | 11:21 AM
DanM's Avatar
Awesome User
I guess I havent checked to be 100% sure, but I just got the block back from the machine shop and that was one of the things they were supposed to do. The surfaces were definitely milled.
Old Feb 25, 2026 | 12:06 PM
BillK's Avatar
Yup. Not sure what I put in the computer earlier to come up with 12.7 lol 10.88 is what I am coming up with now.
Old Feb 25, 2026 | 07:17 PM
You can take as little as .005"-.007" off the block to leave "mill marks" and still be .020" in the hole. Did you or the machine shop actually CC the heads ?
Old Feb 26, 2026 | 05:20 AM
cutlassefi's Avatar
Ok. Simple question, do they have the rod, crank, and piston info to determine what “zero” deck would be? I’m curious.
Old Feb 26, 2026 | 05:30 AM
DanM's Avatar
Awesome User
Yes, they had all the parts when it was done, and also did a crankshaft balancing with all the parts.
I will verify when I assemble it later, but assuming for now that it was done.
Old Feb 26, 2026 | 08:08 AM
DanM's Avatar
Awesome User
That's the cc spec given from Edelbrock.
Old Feb 26, 2026 | 08:15 AM
cutlassefi's Avatar
They’re normally pretty close, maybe a cc or so off but normally pretty good.
With a 10.6ish comp ratio, your cam choices could go fairly large and still have decent vacuum. Just make sure you degree the cam correctly upon installation.
Old Feb 26, 2026 | 08:40 AM
DanM's Avatar
Awesome User
Is there a can you might be able to suggest, or have an idea of what durations/lift/etc would be good?
Old Feb 26, 2026 | 09:01 AM
BillK's Avatar
Dan,
I would reach out to a couple of the cam manufacturers with all of your specs and ask them to make a recommendation. I doubt that anyone here has a car/engine combination exactly like yours so it is very difficult to give you suggestions.
Old Feb 26, 2026 | 10:35 AM
cutlassefi's Avatar
I have a grind that’ll work well in that, with plenty of lift to make use of the heads.
let me know if you wanna move forward with that.
Old Feb 26, 2026 | 03:37 PM
DanM's Avatar
Awesome User
sent you a DM @cutlassefi
rgs455
Oct 2, 2025 04:18 PM
dc2x4drvr
Aug 27, 2022 09:23 AM
Jon442
Sep 13, 2020 03:06 PM
Snakesolds
Apr 21, 2020 10:14 AM
69convertible
Ninety-Eight
Dec 8, 2008 05:39 AM
