Cam selection...or custom grind?
While I have perused the forums somewhat, I've never come across a thread that really matches my combination or intended purpose...
I've got a BBO i'm building .30 over with (for now) Ga heads that i'm going to clean up a little bit myself. I do plan on eventually swapping out for pro-comp heads when i have the money. It will have 2323f pistons, so i'm expecting decent compression. It will be hooked to a built up 4l60e.
I currently have ~2.73 rear gears in a 8.5 10-bolt... which the gears will be swapped out in the future and a posi installed as well.
It will be fed by an EZ-EFI into an intake manifold i have yet to decide on.
I am looking for recommendations for a cam that will give the most performance, but be as tame as possible at idle. I plan to mostly just drive it around town and to the track once in a blue moon, for fun.
Just about any mild cam will do for your build. I think an old high energy comp camps 268H would work well as it sits now. Hydraulic roller with about 220-224@.050 and .550 lift would be good once you swap over the other heads and gear.
I currently have ~2.73 rear gears in a 8.5 10-bolt... which the gears will be swapped out in the future and a posi installed as well. What gear are you going to?
It will be fed by an EZ-EFI into an intake manifold i have yet to decide on. EZ 1.0 or 2.0?
Thanks.
Sorry about that, posting from my phone is not that fantastic. As far as I have seen, hydraulic roller cam and lifters are more expensive as far as initial cost over a flat tappet. I did a can swap in my 350 olds and installed a comp thumpr cam, not the best idea with the low comp, stock converter, and right at the limit of the ez-efi.
I would definitely welcome your input and feedback if possible. Any ideas what a custom grind would run?
Given your ultimate combination I'd do a 228/228@.050 on a 112. Lift would be .568 on both. Again in anticipation of the Procomp heads and EZ 1.0.
