Calling all EFI gurus!!
Old Apr 18, 2023 | 07:14 PM
Redyota's Avatar
I have been working for the last couple of weeks tuning a Terminator X Stealth TBI. It runs pretty well, but I've quickly learned that this is not a fully self learning system. My question is mostly around the Target AFR and Timing Tables. I've been using plug color as well as adjusting Target AFR and Timing to achieve the highest MAP reading and going from there. The car runs pretty good, but after about 30% TPS it starts losing power. I also have a freeway speed only overheating issue. I know that my exhaust is constricted and is going to be replaced by a 2.5" true dual with Magnaflows next week. I would love to have somebody more experienced take a look at my tune and give me some feedback. My CL compensation is under +-2 so my Fueling table is pretty close, but I need to smooth out my Target AFR Tables. I personally think I need to lean out my idle and my cruise a bit, but I'm keeping it a little rich until I work out my overheating at freeway speed.
File Type: zip
Old Apr 19, 2023 | 07:06 AM
cutlassefi's Avatar
The Holley wideband feedback tends to show leaner than it really is. Your Target air/fuel table isn't terrible, I've seen worse.
But without knowing your combination I can't comment on what your base targets should really be.
Old Apr 19, 2023 | 04:03 PM
Redyota's Avatar
Its a stock 75 smog 455 with the original EGR intake that I've disabled. Th400 and 3.36 posi running 225\75R17's. Any other info you might want?
Old Apr 19, 2023 | 04:12 PM
Redyota's Avatar
Another issue I'm having is getting my Idle down. I have checked, rechecked and checked again for any source of vacumn leaks and fixed several. I can get it to 700, but with both primary and secondary adjustment screws all the way out, the only way for me to drop it any further is to physically push down on the secondary linkage. Only leak I have left is that with the IAC at 0, i'm pulling in a lot of vacumn from the IAC port. If I plug it however, it doesnt seam to lower the rpm any lower.
Old Apr 19, 2023 | 05:21 PM
cutlassefi's Avatar
Originally Posted by Redyota
Another issue I'm having is getting my Idle down. I have checked, rechecked and checked again for any source of vacumn leaks and fixed several. I can get it to 700, but with both primary and secondary adjustment screws all the way out, the only way for me to drop it any further is to physically push down on the secondary linkage. Only leak I have left is that with the IAC at 0, i'm pulling in a lot of vacuum from the IAC port. If I plug it however, it doesnt seam to lower the rpm any lower.
The secondary plates are known to stick. try a stronger spring or you may have to loosen and re center them.
Your timing is pretty aggressive in the lower rpm stages and light up top, Your tables aren't scaled correctly for your application either. Rev limiter set at 6800? Really, hmmm.
Old Apr 19, 2023 | 05:46 PM
Redyota's Avatar
yeah, I may have missed that.
I used have the timing in the top end closer to 50, but I'm fighting an overheat issue only at freeway speeds, so I backed it off a ton. I'll take a look at loosening and adjusting the secondary plate. What's your thoughts about the IAC pulling air even when commanded 0?
I see an option in the Terminator X software for a progressive linkage. Have you ever tried it? Its super touchy right at throttle tip in.
Old Apr 20, 2023 | 04:12 AM
dc2x4drvr's Avatar
https://forums.holley.com/
Lots of help here^^^^^
Redyota
May 21, 2023 05:50 AM
Andy
Jan 18, 2022 07:14 AM
russell-t
May 14, 2012 09:01 AM
cuttyroe
Mar 26, 2011 04:26 PM
southcarolina803
Aug 11, 2008 09:18 AM
