Burning Oil
Old Dec 3, 2010 | 02:32 PM
1971 442 convert's Avatar
1971 442 convert
Burning Oil
Have a 455 with 100,000 miles (I believe), and have been dealing with some excessive oil burning. It seems to be worse at higher speeds. Had the valve seals replaced and still burning about 1 quart every 300 miles or so. I have approx. 1000 miles on since the valve seals were done. There are no apparent oil leaks just a little drip here and there but there was some residue on the bumper especially after higher speeds eg. 70 mph. I am using 10 w 30 oil.
Would I notice instant improvement after valve seals?
Am I headed for a rebuild?
Any other suggestions?
Thanks for your input.
Old Dec 3, 2010 | 03:02 PM
Oldsmaniac's Avatar
A compression test will tell you if rings are worn. Teat first then squirt some oil in the cylinders and test again. Are any spark plugs oil fouled?
Old Dec 3, 2010 | 03:33 PM
1971 442 convert
Had a compression test before valve seals and lowest was 108 the rest were 115 to 132. Did not put oil in and retest. Have not pulled any spark plugs yet. Do I need to pull them all?
Old Dec 3, 2010 | 04:21 PM
Red71's Avatar
when you did the seals, were any of them broken/ missing?
I have seen these block the oil return on the heads,then the only place for the oil to go
is to flood the guides. Or the returns could just be plugged with gunk.
later....
Old Dec 3, 2010 | 04:26 PM
1971 442 convert
yeah apparently they were really cracked up.
Whats involved to check this?
Would this make sense then that the faster I go the more oil I burn??
Old Dec 3, 2010 | 05:22 PM
Red71's Avatar
yes, because the more RPM, the more oil pressure,the more in the valve covers.
I would bet a six pack that is what problem is.
take the valve covers off, . Look for the the top row of head bolts, the bolts that are
at the outer edge/ the ends of the heads. there are small little holes that oil is suppose to
drain down to the block. you should be able to stick your small finger in there part way.
you may need a light to see in there. Each head has two holes ,one on each end.
Maybe someone can post a picture of what to look for. I am sure I don't have
any pics.
Old Dec 3, 2010 | 05:58 PM
Red71's Avatar
I found a pic..see the pocket infront of the valve spring? make sure it is clear.
Old Dec 3, 2010 | 06:40 PM
cutlassefi's Avatar
The 108 may be part of your problem. Plus putting on new seals can sometimes be a band-aid if you have bad guides/worn valves, not to mention worn rings.
The rings of yesteryear don't last like todays stuff.
Old Dec 4, 2010 | 08:26 AM
1971 442 convert
Thanks boys I will start with a couple of plugs first.
Old Dec 4, 2010 | 08:45 AM
Rickman48's Avatar
Just had the same problem w/ a '65 400 - Left rear cogged w/ vave seal material!
A real PIA w/ master + booster in the way!
Used a coat hangar, penetrating oil, and air pressure - took about an hour!!
Old Dec 4, 2010 | 08:59 AM
1971 442 convert
Here are a couple of plugs how do these look?
Old Dec 4, 2010 | 10:05 AM
Red71's Avatar
the darker colored one looks to be a possible
problem cylinder.Is that the cyl. that is 108 ?
did you take a valve cover off?
Old Dec 4, 2010 | 11:36 AM
1971 442 convert
Darker colored is the first cylinder which was 132
The 108 is the lighter one.
I did not take the valve cover off not sure I am that mechanically inclined LOL
Old Dec 4, 2010 | 11:56 AM
Red71's Avatar
I think that plug looks fine. You need to find someone to help you
take the cover off. (IMO) If your car has a/c, start with the passenger side.
Old Dec 4, 2010 | 12:03 PM
1971 442 convert
Thanks RED I will get someone to help me and no AC.
Sorry whats IMO?
Old Dec 4, 2010 | 12:20 PM
Rickman48's Avatar
The 400 I worked on smoked BAD at ide, and again during acceleration @ 98k. miles.
Uncogging the drain hole and new valve seals eliminated 99% of the smoke!
Don't forget - plastic back then, is nothing like it is now!!
Of the 4 or 5 seals I pulled off intact, I could shatter them by squeezing them with my fingers - hot and cold cycles make that old stuff real brittle!
I'm not sure if the new seals are any better - but they work for now!
You might be charged around $200 to do the job, but look for someone that's done it before - no novices!!
IMO=in my opinion!!
Old Dec 4, 2010 | 12:24 PM
1971 442 convert
Thanks Rickman.
I do not have any smoking that I am aware of just disappearing oil? At higher speeds I can use a quart in 100 miles or less??
I believe it has got better since the valve seals. When I was on my way to the nationals and doing 75 on I95 that's when the oil just started to go.
I hear you on the plastic thing they said mine were very brittle.
Old Dec 4, 2010 | 02:55 PM
Red71's Avatar
Smile
IMO = in my opinion.
Rickman, I got a 425 free once because of that. they thought it was junk.
you can start on either side, I just thought it may be easier with less stuff in the way.
I some times forget what some of you guys have to work around on these cars.
Mine is set up for racing, It is very easy on my car to work on. No heater,no a/c
no inner fenders.
Old Dec 4, 2010 | 03:57 PM
1971 442 convert
Thanks Red.
God I'm dumb or is that GID
Old Dec 7, 2010 | 05:08 AM
1971 442 convert
The oil returns were clear so I am in the process at costing out a rebuild.
Thanks for all your input. I will start a new thread once I get the costs and particulars of the rebuilds for your comments.
kanek4
Jun 14, 2022 05:22 PM
Mbuck66
Jul 27, 2014 08:39 PM
sunsetlimited
Jul 5, 2012 10:54 AM
oldsdroptop
May 12, 2010 06:06 PM
smcurro
Feb 2, 2009 11:27 AM
