Bolt kits?
Bolt kits?
ok I'm about tire of jacking around. I want all new bolts for the water pump, oil pan, and torker intake. Where is the best cheapest and fastest place to get them? Also, if it's going to take a few days I might as well get a new timing cover. Thanks.
Give these guys a call and tell them what you need. I used the Polished Stainless Allen kit.
https://alloyboltz.com/catalog/index...p0bf0n1qhp19e0
http://www.totallystainless.com/ Been using these guys for many years. THey even have Grade 8+ stainless bolts!
A local fastener (bolt) store like Fastenal or similar. Just make a list or carry over samples of what you need. Non corporate type stores will allow smaller quantity purchases. This place is pretty good for internet purchases.
http://amkproducts.com/
If you want to mount the stock accessory brackets, you will need the special bolts with stud heads used on the water pump and front cover. Totally Stainless does list these parts in their catalog.
Ordered kit from alloyboltz. Stud kit from totally stainless are built to order and don't have time to wait so just going to take bolts from kit and match Up studs locally. Anyone have a list of which bolts need threadlocker or antiseize?
