Blowing Oil
Old Dec 3, 2006 | 05:53 PM
Gwillett's Avatar
Exclamation Blowing Oil
Hope someone can help. I have a 455 in a jet boat which is blowing oil out of the dip stick tube. Any suggestions?
Old Dec 4, 2006 | 05:45 AM
ozoneblue's Avatar
455 oil
Check PCV to make shure its not clogged ,Are you useing a breather type oil cap?
Old Dec 4, 2006 | 05:54 AM
Oldsguy's Avatar
Past Administrator
What is your oil quantity and what size pan are you using?
Also, try this or other threads at that site. good stuff.
http://72.22.90.30/phpBB2/viewtopic....ht=blowing+oil
Old Dec 4, 2006 | 06:04 AM
Gwillett's Avatar
I check the PVC and replace it.It has a 10 qt. oil pan on it.It idles and start
great.but once you throttle down on it,thats when oil comes out of dip stick.
No smoking.
Old Dec 9, 2006 | 07:26 AM
Gwillett's Avatar
Would a Blown head gasket cause pressure build up in the lower end.
Old Dec 9, 2006 | 10:56 AM
VegasDelta's Avatar
Sounds like you're getting blowby past the rings. Try a compression check to verify. Good luck.
Old Dec 9, 2006 | 02:13 PM
Gwillett's Avatar
When I do a compression check what I am I looking for????
Blown head gasket or Broken ring?
Old Dec 9, 2006 | 03:01 PM
VegasDelta's Avatar
Remove all the plugs, check compression in all cylinders & write down the results. Low compression in adjacent cylinders usually indicates a blown head gasket. If readings are low overall, add a tspn of motor oil to each cylinder as you re-check the compression. An increase in compression indicates worn rings, no increase indicates worn valves.
A blown head gasket can sometimes cause oil in the radiator or water in the crankcase. Good luck.
1001coins
Apr 23, 2014 06:11 PM
Big John 85
Jun 14, 2009 05:37 PM
Bluevista
Drivetrain/Differentials
Sep 8, 2008 01:14 AM
edj1993
Jul 9, 2008 09:53 AM
