B or C heads? Same performance?
Old Jun 23, 2011 | 01:00 PM
budgdawg's Avatar
I've got a '66 425 with B heads i plan to use in my '67 Cutlass. I have a '69 455 with C head also, but i'm going to use the 425 b/c of the internals. Since i have both sets of heads, i was wondering if there was a performance or flow difference. I know I'd have to enlarge the pushrod holes on the C b/c of the *45 cam bank, but that wouln't be really necessary if they are the same performace wise. Both came out of 88's from each year. Opinions?
Old Jun 23, 2011 | 04:05 PM
442Harv's Avatar
If it were me I would use the B. Being they both need to be rebuilt,The C will not flow that much better than the B. Then you can sell the C if you want, and they will be easier to sell than the B heads.
Old Jun 23, 2011 | 11:12 PM
64Rocket's Avatar
Use all the guts from the 425 in the 455 block. That way you can get any cam real easy. "B" heads "C" heads not a noticeable difference. Do port work and you will be better off.
take .020 off the block and .020 off the heads and that makes up for the fel-pro .040 head gasket.
Gene
Old Jun 24, 2011 | 06:04 AM
507OLDS's Avatar
Use either pair.No difference.
Old Jun 24, 2011 | 10:18 AM
Run to Rund's Avatar
Good tip above on using the later block. The 66 425 uses the old 45 degree ifter angle and needs a specially ground camshaft. The 455 F block uses the common 39 degree and you can use off-the-shelf cams. you can put 425 piston and rods into a 455 block, but would have to grind reliefs in the 425 block to put 455 stuff in it.
hoppers69
Apr 30, 2012 06:55 PM
wmachine
Dec 30, 2009 05:55 AM
jeffreyalman
Jun 6, 2009 06:28 PM
66JET
Drivetrain/Differentials
Jan 6, 2007 02:33 PM
Super88inWilm
Mar 30, 2006 04:32 AM
