auto or marine / difference???
Old Apr 25, 2009 | 05:09 PM
ctrain22's Avatar
Is there a difference between an auto 455 and a marine 455? Is the boat application different? If so, which is better????
Old Apr 25, 2009 | 06:33 PM
citcapp's Avatar
No difference engine wise, some of the marine engines came with Ka heads which are very good heads and they also came with 4-speed flywheels and the cranks were usually drilled for for 4-speed transmissions. If it is currently in a boat you will most likley have to change the oil pan and maybe add a water pump dependiing on how it was cooled.
Old Apr 25, 2009 | 10:16 PM
Lady72nRob71's Avatar
Same carbs also?? I recently got a 7042250 carb that had the hit idle compensator removed and lead shot put in its place... I thought maybe it was from a martaine or special epplication...
Old Apr 26, 2009 | 08:19 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Marine carbs are always modified to prevent any fuel from spilling out onto the intake manifold. This includes modifying the throttle shafts and changing the j-tubes on Holley's. Distributors, alternators and starters are also different to prevent sparks in the engine bay.
monzaz
May 15, 2012 01:23 AM
4BRL69
Jun 22, 2009 07:05 PM
scrappie
Jan 3, 2009 10:32 AM
Topless72
May 17, 2008 04:45 PM
wizz
Nov 24, 2007 03:36 PM
