Is anyone running a Rocket Racking 2-PC Timing cover?
Old Mar 24, 2024 | 12:29 PM
OLDScience's Avatar
Is anyone running a Rocket Racing 2-PC Timing cover?
I just need to know if the oil slinger is absolutely necessary? Went to put the bottom cover on and it interferes with the slinger. The boss for the seal is pretty thick (wide and deep). so even if I make it clear there's not much room for any slinging anyway. I may have to call John tomorrow, but if anyone knows the answer, I can keep going on putting my oil pan on....Thanks in advance
Old Mar 24, 2024 | 12:38 PM
I forgot to install the oil slinger when I rebuilt my engine in 1982. No issues so far.
Old Mar 24, 2024 | 12:42 PM
Fuhgeddaboudit
Old Mar 24, 2024 | 03:33 PM
OLDScience's Avatar
Ok , thanks for the quick reply...I'm going to leave it out. Couldn't do anything about it anyway, so out it is! The only thing I read is that the rubber seal will get more hot oil than "with" the slinger, so maybe that's a potential for premature failure, but I used a National Seal (NOS) and hopefully it will last...thanks again
Old Mar 24, 2024 | 03:35 PM
OLDScience's Avatar
Fuhgeddaboudit
Cheers Norm
Old Mar 25, 2024 | 05:49 AM
Olds did not spend the money on parts that were unnecessary. The slinger is intended to minimize the oil on the snout of the crank that would otherwise build up against the front seal and cause a leak.
Old Mar 25, 2024 | 09:11 AM
OLDScience's Avatar
I would have to fabricate or modify a slinger to make it work with the 2-Piece cover. The lower cover is installed and so is the oil pan, so time will tell at this point. Other threads and other sites have the same 50-50 opinion on slingers, so the motor will run , but the longevity of the seal was always the concern.
Do you know what the actual failure mechanism is? Heat / Chemical of both? Does the rubber deteriorate/ harden when it fails? I never had one fail, and don't know what a failed seal looks like.
Old Mar 25, 2024 | 07:43 PM
FStanley's Avatar
Can you explain why the slinger won't work as is with the two piece cover? Curious
Old Mar 25, 2024 | 08:59 PM
OLDScience's Avatar
The timing cover boss (at least the one I have) for the seal is much thicker since it's aluminum. Being thicker and thus wider the slinger does not fit around the boss.
Old Mar 28, 2024 | 04:34 AM
chadman's Avatar
I have left them out and never saw a difference. I think it's more of a splash shield for the seal than an actual "oil slinger". The timing chain will get plenty of oil regardless.
Bubbasred69
Jun 23, 2019 09:17 PM
costpenn
May 27, 2015 06:43 PM
truckerlary
Apr 20, 2015 07:14 AM
63super88
Apr 6, 2014 06:51 AM
jason
Mar 19, 2014 02:49 AM
