Any concerns going from 425 to 455 ?
Old October 3rd, 2008, 01:15 PM
Registered car nut
nonhog's Avatar
I have a 65 Cutlass with a 425 (year ?) and its pretty tired , I have a 455
(1970) that came with the car . I might toss in the 455 and see how it does, anything to be careful of or look out for ?
Seems it would be a straight forward swap ? thanks!
nonhog is offline
Old October 3rd, 2008, 01:18 PM
Oldsmaniac's Avatar
They are the same externally
Oldsmaniac is online now
Old October 4th, 2008, 08:38 AM
Run to Rund's Avatar
Balancer on the front and flexplate/flywheel are different. Different water pump snout lengths for different year ranges.
Run to Rund is offline
Old October 4th, 2008, 07:13 PM
Past Administrator
Oldsguy's Avatar
Go for it, and good luck.
Oldsguy is offline
Old October 5th, 2008, 07:21 AM
The water pump length varies due to A/C or non-A/C. It is not related to year or engine size. Use the pump that matches the brackets and pulleys you plan to use.
joe_padavano is offline
Old October 5th, 2008, 08:42 AM
My experience has been that in 66, for example, all water pumps are about 5.12" height; AC pumps have a .75" diameter circle near the pass side port. I think it was about 68 when Olds went to the 5.62" height.
Old October 6th, 2008, 08:32 AM
Registered car nut
nonhog's Avatar
Thanks guys , I am pretty sure both engines have pulleys on them .
So I should be able to "drop" in 455 but if nec. steal parts of the 425 ?
I am not worried.
Now the important stuff run headers ?(got em) Run the 2 spd . till it dies?
put in the T350 at the same time ? (not real hot on adding the floor shifter)
Just stuff for me to figure out !
nonhog is offline
Old October 6th, 2008, 09:24 AM
The difference in water pump heights is a function of A/C vs. non-A/C. It is not generally related to the year. The pump height is matched with the brackets and pulleys. Use them all as a matched set.
Old October 7th, 2008, 04:58 PM
Joe, if you get to NM or NV, I will show you some AC pumps for 66 that are 5.12" high, just like the non-AC pumps. I don't know much about any other years. Since I never use AC pulleys either, I suppose it is possible Olds used 5.62" pumps then but the GMPD parts book doesn't list anything but the 5.12" high pump in 66 (388182 regular, 388183 AC).
Old October 7th, 2008, 06:44 PM
Actually, the A/C pump is also the HD cooling pump. My W-30, for example, uses a long nose "A/C" water pump in a non-A/C application. I was simplifying my response (since I'm lazy ), but my response remains the same: Use the pump, pulleys, and brackets as a matched set.
costpenn
Drivetrain/Differentials
47
April 16th, 2013 10:30 AM
costpenn
November 16th, 2012 04:06 PM
Seff
November 15th, 2012 07:48 AM
62radarlove
March 7th, 2012 09:23 AM
scott_442
Paint
February 5th, 2009 01:39 PM
Quick Reply: Any concerns going from 425 to 455 ?
